Battery question
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by MPGnutcase, Jun 27, 2013.
  1. MPGnutcase
    MPGnutcase Active Member
    579
    114
    Chicago
    when I got home from work today on my Prius 2012 the battery guage was almost full then I went out hours later it was on half? everything was off outside temp 91, ran A/C home...............
    Should I be concerned? :(
  2. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Are you sure nothing was left on, when doors are ajar or convenience lights are left on, the drain is generally on the 12v You are speaking of the HV Bat, right. ? Gliches do appear in the Prius computers from time to time. Possibly even that half charge indication was a glitch and not accurate. Wait til it happens again, then se the dealer.
  3. MPGnutcase
    579
    114
    Chicago
    The next day it was drained to 2 dash's, going in to dealer Tuesday tp check out
    52,032
    all the best!(y) let us know what they find.
  5. andyprius
    2,212
    188
    Definately a problem there.
  6. MPGnutcase
    579
    114
    Chicago
    yesterday and today it's been fine? Dealer can check it over at least it will be on record
  7. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    I see at least 2 bars difference indicated on a HOT battery vs a cool battery. IOW it drops at least 2 bars over night when it cools down.
  8. Bob G IA
    Bob G IA Member
    167
    51
    How long of a drive did you have on the day it dropped to half, then 2 bars, and then on the days it was OK?
    Did you run on EV mode any?
    The reason I asked about how far you drove is because on a cool morning the system will try to use the battery if it can instead of the ICE to allow the ICE to warm up under minimal load. If the speed and accelerator position are such that it needs the ICE it will use it but under low speed and light pressure on the accelerator pedal the battery will be doing most of the work for the first 30 to 60 seconds, depending upon the temperature. This could explain getting down to 2 bars.
    I also noticed something a couple of days ago when I was doing a fair amount of driving in EV mode. The ICE came on at 2 bars and the battery slowly worked its way back up to 3 bars. I then went down a couple of steep hills. The first hill didn't seem to affect the number of bars. However at the bottom of the second hill it went from 3 bars to 6 bars. It may have been the case where the number of bars is updated like every 30 seconds so the sample/update rate was too slow to catch the first hill and the amount of regen it provided.
    Good luck. Hopefully there won't be any issue for you.
  9. MPGnutcase
    579
    114
    Chicago
    91 out using A/C, driving about 70 miles each day --no I have not been using the EV mode at all
  10. andyprius
    2,212
    188
  11. andyprius
    2,212
    188
    It sounds like you have some sort of drain, maybe even a short circuit draining the HV Batery. HV = High Voltage.
  12. andyprius
    2,212
    188
    Loose connections can alsodo this
  13. macman408
    macman408 Electron Guidance Counselor
    1,179
    367
    The battery gauge is a guess at best. There's no foolproof way to tell the amount of energy stored in a battery without draining it. Basically what the Prius does is while you drive it, it counts how much energy goes in, and how much comes out, and uses those numbers to update the gauge. When you turn it on, it's in a better state (usually) to get an idea of how much is stored by the voltage alone (which, when driving, can fluctuate due to recent charging or discharging or heating), so it can recalibrate the gauge to a certain extent.
    So, assuming that your car is in fact being turned off (the battery is physically disconnected from all possible loads when the Ready light is off), then you're not losing any energy from your battery - the gauge is just showing normal inaccuracies.
  14. MPGnutcase
    579
    114
    Chicago
    I never turn the radio off but the A/C was off dome lights off, headlights off, doors shut, it did it for 2 days now it has been fine --- because it's going to the dealer this morning..............
  15. szgabor
    szgabor Active Member
    994
    175
    Oceanside NY
    not necessarily the car keep estimating the charge in the battery from measuring currents in/out in hotter tempreature higher load (A/C) this guesstimate can be out of whack quite a bit by the time you stop.
    I have seen both higher or (mostly) lower indicated bars next startup. At startup the computer again "estimates" the SOC but at this time it can do a lot better job, no overheating cells most likely not having static charge on them so from temp and voltage it can pretty well estimate SOC .. then the game start again and computer calculates SOC not measuring it.
  16. MPGnutcase
    579
    114
    Chicago
    OK so dealer says it all checks out ,,,,,everything cool they did a Health check on system,,,,,,,,,,,,,,,,,,,
  17. andyprius
    2,212
    188
  18. andyprius
    2,212
    188
    From your initial post, I would say there is a problem. No matter what the dealer says, keep an eye on it.:sneaky:
  19. MPGnutcase
    579
    114
    Chicago
    I will keep a eye on it
