Battery recondition "myth or fact"
Discussion in 'Gen 2 Prius Technical Discussion' started by Thumb, Jun 6, 2015.
  1. Thumb
    Thumb Junior Member
    Greece
    Hello
    I reading all these posts about the battery reconditioning but I have a question.How the discharge/charge cycles increase the capacity since it has no memory effect??Why the cars charging and discharging system can not make itself the reconditioning??
    If the reconditioning is true how is possible to discharge/charge the battery with the hobbyist chargers??these chargers has low discharge current and I think has no stable voltage supply...
    Sorry for my poor English!
    Thumb
  2. jdenenberg
    jdenenberg EE Professor
    3,926
    1,923
    Trumbull, CT
    2020 Prius
    LE AWD-e
    The "reconditioning" effect is due to equalization of the charge in the 6 cell in series in a module. This occurs during the last part of each charging cycle as the fully charged cells dissipate excess charging current as heat while the not yet fully charged cells get a bit more charge.
    In the car, the battery is never overcharged so equalization of weak cells does not occur.
    JeffD
  3. ChapmanF
    17,345
    There are a lot of different threads around describing different approaches that you might think of as 'reconditioning' ranging from the addition of lost water to purely electrical approaches. The purely electrical approaches use various techniques, including a high-voltage charger across the entire series battery, or RC hobby chargers across one module at a time. Many of the RC chargers are more sophisticated and better regulated than you might think.
    The replenishment of water is an easily understood reconditioning step that the car clearly isn't able to do on its own. The people who are actively researching that technique are putting their modules through several charge-discharge cycles after adding the water, and it seems plausible that it could be necessary to do so in order to bring old crystallized electrolyte back into solution, etc.
    What most people are doing with a charger alone is more or less limited to trying to bring the battery into better balance. A battery that only charges and discharges through many cells in series will have an inherent problem where small differences in the cell capacity will result in ever-larger differences in charge state. A very slow, controlled overcharge can reverse some of that effect, but you wouldn't want to do it all the time, because for the longevity of the battery, the car usually tries to control state of charge within 40 to 80 percent.
    As for why the car couldn't do that itself, a number of us (at least in Generation 1 cars) have indeed noticed that on rare occasions, the car departs from its 40 to 80 percent control scheme, brings the battery to 100% and holds it there for a while, then drains it back into the normal range.
    -Chap
  4. Thumb
    Thumb Junior Member
    Greece
    The nimh batteries make crystals in electrolyte????
  5. Patrick Wong
    18,200
    6,493
    The concept is that as the battery module heats up during the normal charge/discharge activity, some water vapor is vented which leaves a higher electrolyte concentration, some of which eventually turns solid.
    miso03 and Thumb like this.
  6. Thumb
    Thumb Junior Member
    Greece
    After reconditioning my Prius modules the only difference is....before reconditioning the modules has 7.6V with 4A load the voltage drops to 6.8V in 15minutes and to 6V in 33minutes after 3 cycles the difference is that the charger charges to 8.3V and with the 4A load the voltage dropped to 6.8V in 30minutes and to 6V in 43 minutes.
    Is this improvement???
