Battery red in carwash, trouble ahead?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by MB31, Jun 15, 2018.
  1. MB31
    MB31 Junior Member
    62
    Netherlands
    Went through a carwash in neutral. Afterwards I vacuumed the car and drove off. When I wanted to pull up between cars on the busy road there was a sudden drop of power causing the car to slow down and other traffic having to slam the brakes as not to hit me.
    It was then I noticed the battery icon on the MFD was red/empty. I drove around some more until it was blue and finally green again. This was two weeks ago and no problems since.
    I am concerned that the battery did not manage to go through thet carwash. I may have had the AC on, not sure.
    Does this mean the batteries are weak and trouble is ahead? One year ago I had the full battery replaced by a revised one.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    What did you replace the hv battery with last year (not sure what “revised one” means)?
    Are there any dash lights?
    What is the warranty on the revised battery?
    I’d say that the battery is weak and is in the early signs of failure.
    Good luck and keep us posted (y)
    49,707
    never go into a carwash that requires neutral, unless the battery level is high and the a/c off. it is hard to determine your battery state of health, but even a good battery can have problems in that situation, and no permanent damage may have been done.
    jerrymildred and jzchen like this.
  4. fotomoto
    fotomoto Senior Member
    5,602
    3,781
    So. Texas
    That's one sign of a weak battery but it's not a guarantee either. Keep an eye on the SOC meter.
    GOOD LUCK!
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,809
    Clearwater, Florida
    yes the battery is weak and in trouble. You are probably seeing very poor mileage also. Who replaced the battery last year?
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,335
    6,011
    Columbia, SC
    There are too many variables here to make an accurate determination if you have a problem or not. There are many many many warnings on this forum about going through a carwash that requires the car to be in neutral (since the HV battery does not charge while in neutral). You are obviously not the first, only, or most likely last, person to experience this.
    How hot was it outside?
    Was the AC running full blast in auto?
    Was the AC running at a low speed?
    These items make a big difference in the current draw of the AC compressor motor.
    What was the initial state of charge when it was put into neutral?
    Could it have already been low from waiting in line at the carwash?
    If you have an android phone, purchase a bluetooth adapter for the OBD port and get some free apps (like Hybrid Assistant and Hybrid Reporter) that allow you to monitor/load test the battery. This will provide REAL DATA and voltage curves, not just keyboard warrior opinions such as mine.
    Petrodollar and jzchen like this.
  7. MB31
    MB31 Junior Member
    62
    Netherlands
    Thank you for all the replies. I did not get or see a notification from the forum so I missed them!
    I think the temperature was was about 27C/80F. Battery could have already been depleted a bit from waiting but not a long line. AC was probably running but not full and not on auto. I totally forgot I was driving a hybrid and did not even check the charge when going in. Remembered just in time to put it in neutral :unsure: I will wash the car by hand from now on!
    Last year I had trouble with the battery, the fan in the back stayed on, the car would not go fast anymore and a lot of lights on the dashboard. I went to 'a guy' who switched the battery out for one 'revised' by him. This meant he would take a faulty battery and switch out all the faulty cell(s) and create a new battery by adding cells he would buy on ebay. Did not have trouble since. Only thing I noticed after the switch is that the car used to drive electric only more often then now as now it almost always turns on the engine now.
    I already have an ODB adapter that I purchased the last time but I thought I could only use ot to read error codes. I will check out the apps mentioned to see if this tells me anything. Thanks!
    bisco and Raytheeagle like this.
  8. bisco
    49,707
    have you L/100km changed?
  9. aznitronut
    aznitronut Junior Member
    16
    US
    What difference does it make, with a/c on or off? What causes this problem?
    SM-G935P ?
  10. Mendel Leisk
    38,884
    Anything that puts more load on the battery will run it down faster. AC falls into this category.
    Maybe late to say, but in future, just avoid those pull-along carwashes, that require the car in Neutral. Preferable are the type where the car just sits and the washing aparatus moves along the car.
  11. edthefox5
    10,096
    4,809
    Clearwater, Florida
    Ac compressor is electric not belt driven. Puts a real good load on the inverter. The inverter literally screams when the ac is on. Its max load.
    Load on the inverter is big load on the hybrid battery. That’s why in limp mode there’s not enough power to run the ac.
    #11 edthefox5, Jul 17, 2018
  12. aznitronut
    16
    US
    Thanks for the info, I didn't know that.
    Living in Arizona, the A/C is always on.
    SM-G935P ?
  13. jzchen
    jzchen Newbie!
    3,298
    1,010
    Arcadia, CA
    Not sure if already said, but engine will not run to charge battery in N. Was the case in our C-MAX, betting similar here....
    edthefox5 and Mendel Leisk like this.
  14. aznitronut
    16
    US
    What happens when we are at a stop light for 30 seconds, or so? Is'nt the same thing? Or rush hour trafic?
    Foot on the brake? Or in park?
    SM-G935P ?
  15. bisco
    49,707
    as long as you are not in neutral, the car keeps the battery to a minimum charge. if you get stuck in traffic, you will observe the bars drop to two, then the engine cycling on and off to keep it there until you start moving again.
    but if you put it in neutral, you will get the warning on the screen, and if you don't take it out, your car will die on the highway.
  16. jzchen
    jzchen Newbie!
    3,298
    1,010
    Arcadia, CA
    In D or P no problem, just in N.
    Sorry bisco, your post hadn’t shown in TapaTalk.
  17. edthefox5
    10,096
    4,809
    Clearwater, Florida
    Be aware "revised" means they replaced the bad modules with modules of the same age that just so happened to be in better shape at that time than the ones that failed on you. So they are not new and all of the same vintage and the clock is ticking on that battery pack.
    The only way to get brand new battery modules is to buy a brand new toyota battery.
  18. aznitronut
    16
    US
    Thanks
    SM-G935P ?
  19. MB31
    MB31 Junior Member
    62
    Netherlands
    Here is an update, the mileage of the care seems the same as usual. But I did discover something else. The car will only charge the battery when I press the gass pedal and am driving. When standing still the engine doesn't run to charge the battery, even if I only have a couple of bars. Combine this with use of the AC and I'm in trouble really fast.
    Does anyone know how this can happen and how it can be fixed? For now I only use the AC on the freeway and not in the city or in heavy traffic (jams). On the freeway everything is fine and even with the AC on often my battery is green.
  20. jerrymildred
    jerrymildred Senior Member
    11,518
    14,124
    Tampa, FL
    The engine WILL run without pressing the gas pedal when the computer decides that the battery needs it whether you are moving or not, as long as it is not in neutral.
    But it does sound like you are close to having to replace the HV battery with a new one or else rebuild it again and keep chasing bad cell. Even a 2005, if it's in good shape otherwise, is a candidate for a new battery.
