Battery Replacement (Auxiliary)
Discussion in 'Generation 1 Prius Discussion' started by ARNY HEYWOOD, Nov 21, 2021.
  1. ARNY HEYWOOD
    ARNY HEYWOOD New Member
    Las Vegas
    2002 Prius
    Long-time lurker here.
    I own 2002 Prius. I'm trying to replace my auxiliary battery. The battery shown on the left in the attached image is the one I'd been using. The one on the right is the battery suggested by Toyota on the basis of my VIN, but two mobile mechanics told me it's the wrong battery. I'm really confused.
    Thanks for your help.
  2. ammdb
    ammdb Active Member
    276
    110
    Indianapolis
    The Toyota battery on the right is correct.
    2002 Toyota Prius Vehicle Battery - 2880021050 - Genuine Toyota Part
    Any 12v AGM car battery with the right size terminals will do the job, the trick is to find one that will fit in the small compartment in the trunk. The battery I use isn't OEM, so I had to cut away part of the battery hold down bracket to make it work.
    #2 ammdb, Nov 22, 2021
    ARNY HEYWOOD likes this.
  3. ARNY HEYWOOD
    Las Vegas
    2002 Prius
    Thank you very much!
  4. nimblemotors
    nimblemotors Re Member
    117
    37
    Sacramento
    2002 Prius
    I noticed in my blue car it had the bigger battery, which required a bigger hold down bracket to fit, vs the smaller one in all my other cars. Also, to get the bigger one in/out you have to remove the plastic tube duct thingy that runs above the battery, otherwise it would NOT pull out of that spot.
    A mazda miata battery will fit and has the vent hose to vent outside the car.
  5. Josey
    Josey Active Member
    305
    117
    Virginia
    2003 Prius
    I have no idea how the battery you've been using fit in that tiny little space. Not very well is, I suspect, the answer. Nor would I guess how the cables reached unless they were modified. Yes, the narrower battery on the right is correct.
  6. ARNY HEYWOOD
    Las Vegas
    2002 Prius
    That was the battery in place when I bought it.
    Thanks for your help!
  7. nimblemotors
    117
    37
    Sacramento
    2002 Prius
