Battery replacement Smart Key
Discussion in 'Gen 2 Prius Audio and Electronics' started by warrior, Jun 26, 2009.
  1. warrior
    warrior New Member
    141
    Paso Robles, CA USA
    What are the indications that the battery in the smart key needs replacing? 2 yrs now.
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Limited range, erratic operation.
    Tom
  3. john1701a
    john1701a Prius Guru
    12,755
    5,245
    57
    If the little red light (on the FOB itself) doesn't illuminate brightly or at all when you push the button, it's time.
    Photos and the change procedure are documented in the User-Guide.
  4. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    Another clue is the car beeping at you for no apparent reason. It beeps when it's on and loses contact with the fob.
  5. whodat
    whodat Member
    117
    Aptos, CA
    Yep, my 06 Prius smart key stopped working. Replaced battery and now it works.
    The spare smart key little red LED comes on when I used the key, so I replaced the battery on the spare smart key as well.
    Thanks for the smart key assembly instructions Prius Chat!
