Battery replacement UK
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Clubber, Oct 14, 2016.
  1. Clubber
    Clubber Junior Member
    24
    London
    Think the battery is on it's way out on my wife's Prius. The car has failed to start on 2 occasions. The 1st time I started it with my jump box and it was fine for a couple of weeks but it did the same this morning.
    Dealer has quoted me £147 for the battery including fitting. £118 to supply battery only.
    Is there a cheaper way to do it?
    Can an equivalent battery be bought and DIY install?
    #1 Clubber, Oct 14, 2016
  2. Mendel Leisk
    38,726
    118 pounds converts currently to $189 Canadian Dollars. I believe that's precisely what Canadian Tire is charging for an aftermarket MotoMaster (rebadged Exide I believe) battery that is flat case AGM, dimensionally identical, correct posts and and vent port, and about a third higher Cold Cranking Amp rating. That's about the cheapest and best deal going here.
    Bottom line, unless battery prices are typically cheaper in Britain, that sounds like a very fair price from the dealership. Again, you might be able to find a compatible aftermarket battery with higher CCA, but I'm not sure what that gains you at the end of the day. For sure the dealership battery will be 100% compatible.
    You can DIY the dealership battery or aftermarket, either is quite easy. Typically they charge what amounts to a deposit, say 10 pounds extra, which you recoup when you bring back the old battery. It's not difficult to do: always disconnect the negative (ground) cable first, and reconnect last.
    You could clean the new battery posts and cable clamps with a little fine sandpaper or steel wool before reconnecting.
    #2 Mendel Leisk, Oct 14, 2016
