Battery Replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by PamR, Jan 23, 2013.
  1. PamR
    PamR New Member
    I have a 2005 Prius, 136K miles and my battery died. Toyota wants $3072 for replacement with a new battery, 1 yr. warranty, unlimited mileage. I found a place online called Greentecauto.com (out of California) that rebuilds Prius batteries for $1345 and they give an 18 month warranty, unlimited mileage. Free shipping to Toyota and then Toyota only charges $300 to install it. Has anyone used Greentecauto? Everything I found online is positive, but would appreciate input from someone who's used them. Thanks!
    JMD likes this.
  2. Britprius
    Britprius Senior Member
    5,194
    1,918
    Herefordshire England
    There are a number of Prius battery rebuilders in the US and from information on here there are no problems. The other alternative is a battery from a late wreck "check on Ebay" they normally come with a short guaranty but are cheaper, and if out of a late vehicle possibly as good, and could even be better.
    John (Britprius)
  3. PamR
    PamR New Member
    Thanks John, I'll check ebay.
  4. Britprius
    5,194
    1,918
    Please let us know the route you go and the final outcome as this helps others in the future along the same path.
    John (Britprius)
  5. bisco
    51,140
    your toyota dealer told you they would install this rebuilt battery for $300.?
  6. Britprius
    5,194
    1,918
    Just one other thought your battery may still be under guaranty. I'm not sure of theUS guaranty but UK is 8years 100,000 miles, in some US states California in particular this is extended to 10years 150,000 miles so worth checking.
    John (Britprius)
  7. PriusCamper
    PriusCamper Senior Member
    12,048
    4,892
    Pacific Northwest, USA
    You oughta change your name to BritBatteryMan... LOL...
  8. Britprius
    5,194
    1,918
    There is nothing wrong with rebuilt batteries, but a the end of the day the modules are all second hand out of different batteries tested and balanced. I see a late battery from a wreck as being all matched modules of the same age and use pattern as being a better bet. For me the best battery would be one built from a 2011/2012 battery with all the modules put in the gen2 housing.
    John (Britprius)
  9. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Yes. OP, where are you located? In CA and CARB states the HV battery is warranted for 10 years/150K miles.
  10. Patrick Wong
    18,200
    6,492
    Compare that price to $1,942 for a new battery, here:
    2005 TOYOTA PRIUS Parts - Champion ToyotaWorld
    PriusGuy32 likes this.
  11. Rick atl
    Rick atl Junior Member
    26
    Atlanta
    2001 Prius
    I just asked myself, would I buy a used laptop battery for 30% off, that's only 6 years and 600 cycles old? lol.
    The new one was a bite to the credit card but should be the last battery I buy for this car, for a long time. and it's NEW.
  12. PriusCamper
    12,048
    4,892
    Is there any cheaper way to get a battery that's new?
  13. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    Go for it. Don't order until you speak to the dealer and make sure they can install and there cost. A salvage part is about $500 but no guarantee. With the hurricane Sandy salvage parts in the field I would think the rebuilt with a Guarantee is the best choice.
  14. JMD
    3,779
    1,282
    With the money you save go to Mardi Gras February 12 in New Orleans.
  15. Rick atl
    26
    Atlanta
    2001 Prius
    The price Patrick found sounds great, but you or your mechanic will want to source it by calling your local dealers. You don't wanna pay shipping on the new one, or the core you're returning to get the $1300 core charge credited back to your car d. They'll expect the core to look non-crushed, non-leaky, read "non-hazardous waste". Hose off the old cells if need be. And you or the mechanic really needs the old battery right alongside the new one, there are about 30 pieces that must be swapped from old to new :). Not hard but you don't want to strip it, put the parts in a pile, and drop it at the dealers... unless you've done 20 of these before.
  16. JMD
    3,779
    1,282
    I may be Enticed to repair and sell the car.
