Battery Suppliers
Discussion in 'Gen 2 Prius Main Forum' started by rdverb, May 28, 2004.
  1. rdverb
    rdverb New Member
    49
    Monterey, California
    Does anyone know the supplier(s) of hybrid batteries to TMC? What about other manufacturers?
  2. Frank Hudon
    Frank Hudon Senior Member
    4,147
    Panasonic TMC joint venture
  3. rdverb
    rdverb New Member
    49
    Thanks, Frank.
    So they must be proprietary ... will the TMC THS licensees (Nissan, Ford) use the same ones?
    Anybody know what Honda or others will use?
    Seems ripe for some real competition.
  4. john1701a
    john1701a Prius Guru
    12,754
    5,245
    57
    Ford will use batteries from Sanyo. 250 in the pack. They are just the ordinary "D" rechargeable NiMH type, literally the kind you can buy off-the-shelf.
    I'm not sure who supplies the NiMH batteries for Honda, but those are the "D" type too.
    Only Toyota uses a propriety design, which offers tremendous benefit; the energy-density is higher than the ordinary NiMH and the form-factor is smaller. There are 28 modules, rather than "D" batteries shrink-wrapped together in sets of 6, allowing the modules to take less physical space. An interesting bit of trivia though is that the module is internally arranged as 6 cells, each providing the same voltage (but more amperage) as a "D" battery.
  5. siai
    siai Junior Member
    50
    Florida Keys
  6. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    301
    Northwest VT
    2018 Prius Prime
    So people who buy the Ford Hybrid can incrementally increase their capacity any time they want :)
    BTW, I hope there are 252 D cells since there are 6 in a 'set' :),
  7. john1701a
    12,754
    5,245
    57
    Nope. One set is shorter. 1.2 volts * 250 cells = 300 volts
    That's same voltage that has been posted in the specs.
  8. plusaf
    plusaf plusaf
    324
    Raleigh, NC
    if they're all in series, 1.2*250=300volts, but it's the voltage, not the amperage, that's increased. you put them in parallel for more current, but you only get 1.2volts.
    it would seems strange to me to have one module of 4 cells, rather than 6, to get an "even 300v". the problems that would come from having two different kinds of cell-stacks, including ordering, inventory, manufacturing, etc., would outweigh the "downside" of adding 2.4 volts to the whole stack, which is 2.4/300, or 0.8% "error", which is hugely smaller than overvoltage tolerances that the whole system would be designed for! i'd be ashamed for them if they had one stack of four and all the rest were six!
    and stacks lend themselves to series, not parallel.
    just the EE in me...
  9. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    American Automobile Engineering at its best!!
  10. Joel
    Joel New Member
    108
    Houston, TX
    Looking to capitalize on this portion of the supply chain?
