Battery Temperature rise after parked
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Nelsonxx, Mar 7, 2024.
  1. Nelsonxx
    Nelsonxx New Member
    Malaysia
    Parked the car for 40mins, the temperature for the hv battery increased from 38c to 48c. Is it because I park it with higher soc(67%)? Cabin temperature is 31c and battery inhale temperature is 33c.
  2. Mendel Leisk
    38,634
    I don't think it's unusual, expect that 10C is quite a difference. When the car's on there's a fan to dissipate the heat. When you park that fan stops, and no more cabin air circulation either. Are you garage parked as well? Or parking in direct sun?
    This has concerned me as well, might be good if the car's programming could run the fan for a few minutes after shut down, depending on the measured temperatures.
  3. Nelsonxx
    Nelsonxx New Member
    Malaysia
    Yes direct under sun open area parking,but is in the morning.after turning on the car with full blast fan speed, the temperature dropped rapidly to 41-43c within minutes.
