battery tender terminal
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Fussion101, Apr 10, 2011.
  1. Fussion101
    Fussion101 Junior Member
    81
    NYC
    I just bought a battery tender plus. Am I able to connect it through the jump start terminals in the front? Obviously I can direct connect from the back but that's not an option right now.
  2. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    Sure you can! Hal
  3. Fussion101
    81
    NYC
    What kind of 12v battery does the 2010 prius have? After I received mine I realized there were two different models. One was specifically for GEL type. Even though they both list as compatible with AGM and GEL.
  4. Mendel Leisk
    42,038
    Ours has a regular lead-acid battery (not sure but think that's the only OEM battery type), and I periodically hook up a CTEK 3300 charger, at the engine compartment fuse box terminal. No problems.
  5. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    The Prius battery is an AGM type, so it looks like you are covered.
  6. Smarter Car
    Smarter Car New Member
    Southern California
    Why does the battery need to be charged unless there is a charging problem with either the car or the battery?
  7. Mendel Leisk
    42,038
    I guess in a perfect world, the short answer would be: it doesn't.
    But, several reasons I can think of for keeping a charger around, particularly a maintenance type, ie: one capable of being hooked up long term, if needed:
    1. For periodic top-up your battery, above and beyond what the car will do.
    2. Some intelligent chargers run a "desulphating" cycle at the start of charging. What that is is a little beyond me, LOL, but it sounds good. They can also give a rudimentary display of your battery's state-of-charge.
    3. They are more-or-less the only way to restore a battery that's been seriously discharged, by accidental lights left on, for example. I don't think the car's built-in charging was designed to handle this.
  8. Mendel Leisk
    42,038
    But, there are several reasons I can think of for keeping a charger around, in particular a maintenance type, ie: one capable of being hooked up long term, if needed:
    4. If you're not going to be driving for several weeks, hooking up to a maintenance charger is cheap insurance.
  9. novaz
    novaz Junior Member
    47
    arizona
    2015 Prius c
    hope I am not thread hacking
    I have a Genius 7200 (7amp) battery charger which gradually cuts amperage as charge is absorbed by battery Is it okay to use this kind of charger as opposed to a trickle charger also do I need to disconnect battery when charging .
    Thanks
  10. Mendel Leisk
    42,038
    Just looking through my 2014 Prius c Owner's Manual, page 501 says to keep the charging rate at 3.5 amps or less. (if you have the pdf search for "charging rate"). I see Genius makes a 3.5 amp model as well, maybe spring for a new charger?
    I'm using a couple of CTEK chargers, the Multi US 3300 (3.3 amp) and the Multi US 4.3 (4.3 amp). Our regular 2010 Prius is rated 4.2 amp max charging rate.
    Typically now I'm hooking up the 4.3, whenever the car's not going to be used for a few days, and just leave it on. After it goes through a charging session it sits mostly idle, occasionally giving the battery a little uptick. I've installed CTEK's supplied quick connect at the under-the-hood fuse box, so I don't have to pop the lid, and it's more secure.
  11. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Newbie question. ;)
    If......the vehicle will sit unused for more than a month (some would say 2 weeks), it is a good thing to keep the 12 V battery fully charged.
    If you do a search on here for "battery", you will get about a million hits; half of them will be about this very subject.
    WilDavis likes this.
  12. Sam Spade
    2,036
    1,023
    2017 Prius c
    No, no and no.
    All battery chargers do that. Unless that model clams to be "fully automatic", it would not be good for long term connection.
    Neither is a cheap trickle charger. It needs to be a fully automatic tender type charger for long term use.
    No you do not have to disconnect the battery to charge it.
  13. novaz
    novaz Junior Member
    47
    arizona
    2015 Prius c
  14. Mendel Leisk
    42,038
    It could be the Genius charger falls into that category. Still, it's a little overpowered, well above the spec'd max charge rate.
  15. RavMan
    RavMan New Member
    Australia
    Both of these chargers are great. You cant go wrong with either one. I have the Ctek as it does the small 12v batteries like motorbikes as well as the larger car batteries. Like others have said the desulfer settings really can make you battery last longer.
