Battery terminal protectors?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Fart, Mar 5, 2022.
  1. Fart
    Fart Junior Member
    Hello!
    I have some of those corrosion preventative battery terminal pads I wanted to install in my 2007. I do use the central control unit and program my maintenance schedule with dates and like seeing how many miles I have left until the next oil change and CVT change.
    If I unplug my battery to install these terminal protectors is it going to erase my data in the maintenance log? If so how can you backup the data or should I just re-enter it after?
    Thank you
    49,489
    idk if it erases, but you can put a 12v source on the jump point
  3. Mendel Leisk
    38,726
    Or a jump pack with memory saver cable plugged into OBD. Either works.
