Battery test still shows 11.9 even after three new batteries back to back with 13 volts shown on my
Discussion in 'Gen 2 Prius Main Forum' started by Darren Hernandez, Mar 10, 2023.
  1. Darren Hernandez
    Darren Hernandez New Member
    Moreno Valley California
    I have read the internet through in and throughout and of course what I come across I don't see anything for literally I was doing the battery check and it came up as 11.9 a few times and the battery was replaced in 2020 as well as 2018 for some reason. I went and bought a new battery and charged it to 13 volts as well as topped off the Hybrid battery from AAA that's in . It won't even get near the same 12.4 let alone acknowledging that it has 13 volts in it not sure what to do any feedback would be great thanks
    49,691
    your post is a little confusing. how and why did you top off the hybrid battery? you got a hybrid battery from AAA?
    what are you measuring the 12v with?
    what 'same 12.4 volts?
  3. Tombukt2
    Tombukt2 Senior Member
    9,596
    1,681
    Durham NC
    What's important here mostly is that the readings from the device you're using are consistent so if your device at your house is reading your battery at 11.9 consistently then I would take that probably as being 12 volts that should not be causing you to replace the 12 volt battery You need to be down you know a complete vault or better not a couple of tenths. In my generation too with a very late model 12 volt and a new hybrid battery and all that nonsense I see 11.7 on the 12 volt all the time or pretty regularly when I do check it which is very rarely and everything is working fine I don't worry about 12.4 to 11.9 to me that's 12 volts and a little bit over that range that I just put above should be fine If you're only replacing batteries because of numbers you're seeing on a digital display of a tool that might not be such a thing.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,790
    2017 Prius c
    I DO wish that people would put some white space in their posts.
    Like this.
    It makes them easier to read and understand.
    How exactly are you getting those voltage readings ?
    And where are you making the connections ??
    IF......you are measuring directly on the battery posts with the car OFF.......
    You should never see 13 volts, except for a few seconds right after the charging stops.
    A healthy new battery might read 12.5 or so while some of the computer boards are still "alive"
    and then should rebound to about 12.8 when all (or most) or the current flow actually stops.
  5. Mendel Leisk
    38,874
    Where are you getting your batteries, and what brand?
    How much driving are you doing, say per week?
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,808
    Clearwater, Florida
    have no idea what you said...
  7. bisco
    49,691
  8. sam spade 2
    7,035
    2,790
    2017 Prius c
    Have no idea WHO you are talking TO.
