Battery Testing and Trickle Charging
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Kent10, Mar 27, 2022.
  1. Kent10
    Kent10 Junior Member
    Flagstaff, AZ
    We have a 2007 and a 2015 Prius. We don’t drive them long distances as much as we used to and so I would like to trickle charge the batteries. The problem for me is that the batteries are in the back and difficult to access.
    I tried testing the quality of the batteries with a battery tester (Konnwei KW208). Am I able to do this from the front using the plus terminal in the fuse box? I tried it and it doesn’t work. Perhaps I need a better location to attach the negative clamp but I did try various places.
    Am I able to trickle charge the battery from the front using the plus terminal in the fuse box? I have a Noco Genius 5 but I am concerned 5 amps is too much for the Prius battery. Should I get a Noco Genius 2? They are good for up to 40Ah batteries but at least one of my Prius batteries is rated at 45Ah so maybe it won’t work? Is there anything better?
    Thanks very much, Kent
    ralph seifer likes this.
  2. JC91006
    16,673
    8,518
    You can trickle charge using the front. For the negative, use the strut bolt. That’s right next to the fuse box
  3. dolj
    dolj Senior Member
    8,217
    4,187
    Wellington, New Zealand
    And yes, the Noco Genius 5 will be perfectly fine for both Prii.
  4. Kent10
    Flagstaff, AZ
    Thanks JC91006 and dolj. Appreciate your help!
  5. BuyJapanese
    BuyJapanese Member
    62
    31
    Wisconsin
    I support trickle charging (and jumping) through the front.
    It will be slower, but it will work.
  6. dolj
    dolj Senior Member
    8,217
    4,187
    Slower than what? Charging directly on the battery?
    edthefox5 likes this.
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    Slower than what?
    trickled my 07 from the front for years and years.
    But the 12 V is not the problem. You let the 07 sit it will kill the hybrid battery not so much for the 2015.
    Plenty of idiots out there that will still buy a G2.
    Get. Rid. Of. It.
    Read all the posts here about all the dead hybrid battery’s on a G2. It’s not if it’s when. And when is always at the worst possible time.
  8. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,799
    2017 Prius c
    Well since nobody else said it..............
    A smart, tender type charger is NOT a "trickle" charger.
    A trickle charger is a specific kind of dumb charger that will keep charging the battery whether it needs it or not and can do some damage over long periods of time.
    Referring to a smart charger as a trickle charger really is giving out bad information.
    Then......the max. capacity of a smart charger is really not important since it will adjust down to the charging rate that is needed at the time.
    Ellyg likes this.
  9. BuyJapanese
    BuyJapanese Member
    62
    31
    Wisconsin
    Yes. 1% slower, 10%, I don’t know but there is SOME added resistance when you’re charging the battery remotely like that. This is not a reason not to do it, but just seems useful to acknowledge that.
  10. sam spade 2
    7,035
    2,799
    2017 Prius c
    While that sounds logical it really is NOT true because the difference is so small.
  11. alftoy
    alftoy Senior Member
    1,132
    514
    Saskatchewan, Canada
    Noco Genius is fine, its a smart charger, adjusts automatically. Pic shows attachment points for charger. Ring terminal connections on each vehicle allows you to move the charger between both vehicles.
    Noco Ring Terminals for Genius 5 are $7.48 each, reg $19.95 Amazon
  12. alftoy
    1,132
    514
    Whaa, Ed having a bad day?
  13. Kent10
    Flagstaff, AZ
    Thanks all. Very helpful. The 2007 has a new Hybrid battery. It died quite suddenly but not from lack of driving. Overall, it has been a great car for us with over 200,000 miles on it. We almost sold it and bought the 2015 but then decided to keep the 2007 after getting the new Hybrid battery. It works perfectly now.
    ralph seifer, Ellyg and dolj like this.
