Battery Triangle light
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ed928, May 23, 2018.
  1. ed928
    ed928 New Member
    Showlow Az
    Hi guys so i am getting code p0a80 i got the toque app to check the voltage on my battery but all the blocks are showing -330 volts only block one is showinf 15.4 is there a explaination for this? all replys appericated. thank you
  2. ed928
    ed928 New Member
    Showlow Az
    anyone guys know why? please help i cant figure it out
  3. TravisPrius86
    TravisPrius86 Junior Member
    Waynesboro, PA
    Possibly a bad cell in the hybrid battery. Check the 12v too.
  4. strawbrad
    953
    1,002
    Wow, at first I thought that 330 volt reading must be just a typo, but it's clear that's what Torque thinks is going on. Torque is very confused.
    Try using the free Hybrid Assistant and Hybrid Reporter apps. They will work with the same reader and Android devise you already have.
    If Hybrid Assistant reports the same nonsense I would suspect the battery computer is faulty.
  5. bisco
    51,140
    how many miles on her?
