Battery trouble? PRIUS 2013 PLUG-IN ADVANCED
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Christi1992, Mar 8, 2020.
  1. Christi1992
    Christi1992 New Member
    Germany
    2013 Prius Plug-in
    Hello guys. I am new here. I own a Prius 2013 plug in Advanced package. Its currently 6 years old and have done 150.000 km.
    My previous car was a 2010 prius that I sold a year ago. I had it for around 5 years before I decided it was time for an upgrade.
    I have these days been playing with the obd and different apps to learn more about this plug in battery. I have done some research of how long distances people get on a full charge, since I only get 15 km or less on a charge.
    Using a app called Dr. Prius I found that module 2 have lowest voltage than the other modules. Voltage differential can vary between 0.20-0.35 Volt. And never equalizer even when the last procent are balance charged.
    So I assume it may have some problems. Since this 4.4 KWh pack have cells and modules connected in a serial configuration it could in long term ruin more cells.
    Car is out of warranty so far and I guess this is an expensive repair to do at dealer if they conclude battery have to be replaced.
    I had in mind to open the battery and test the cells in the module and see which one is failing, and then swap out the cell with a new one.
    Something I did this on my previous 2010 prius.
    What would you guys suggest?
    Below attached picture of the battery result. Screenshot_20200307_160943_com.nexcell.app.jpeg Screenshot_20200307_093631_com.nexcell.app.jpeg
    nesoccer likes this.
    52,390
    I would suggest a test drive on flat ground in nice weather with nothing on, around 30 mph with as few stops as possible.
    If you get 11 or 12 miles, everything is fine
    N.J.PRIUS and Christi1992 like this.
  3. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    Wait for warmer temperatures. Your 15 km is just about right for 7 to 10 degrees C.
  4. QuantumFireball
    QuantumFireball Active Member
    420
    269
    Ireland
    There is no extended hybrid system warranty in Germany? With annual checks it's up to 15 years in Ireland and the UK now.
    Mine was showing about 14 km on a full charge this winter, but in reality I could drive slightly further than that. I live around a lot of hills though. Driving conditions, tyres and other things will affect range.
    You should perform the battery test in Dr. Prius, looking at the voltages with a high SOC may not show the full story.
    Christi1992 likes this.
  5. Christi1992
    Germany
    2013 Prius Plug-in
    They told me the warranty covers up to 100.000 km or 8y. I asked about extending the warranty, they said it won't be possible...perhaps I could try ask another dealer and see if they say the same.
  6. QuantumFireball
    420
    269
    Ireland
    The Hybrid Health Check thing is either available nationally, or not at all.
  7. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    That's shocking!! Here' it's 100,000 MILES which is 160,000 km or 8 years. That's a big difference.
    13PIP91326, N.J.PRIUS and Christi1992 like this.
  8. bisco
    52,390
    No codes, no warranty
    Christi1992 and jerrymildred like this.
  9. jerrymildred
    11,517
    14,158
    Tampa, FL
    Good point. There is no warranty against simple reductions in EV range.
  10. Christi1992
    Germany
    2013 Prius Plug-in
    Thanks for reply guys, I haven't yet been to another dealer to check it,since I've been busy.
    What I have done to improve the voltage differential between the cells where I took it to a charge station in a near empty SOC. Put the car into N(Neutral) and run seat heaters and AC to empty the battery as much as I could. (Engine kicked in) , however it wasn't able to charge the battery when in Neutral. I took it below 15% SOC measured with OBD.
    Turned the car off and plugged in the socked and charged it full.
    Came back later and checked the voltage differences between the cells and found highest and lowest voltage differential where 0.10-0.15V which where an improvement.
    QuantumFireball and dig4dirt like this.
  11. bisco
    52,390
    interesting approach
    Christi1992 and dig4dirt like this.
  12. jerrymildred
    11,517
    14,158
    Tampa, FL
    Interesting indeed!
  13. dig4dirt
    dig4dirt MoonGlow
    1,151
    741
    Lancaster Co PA
    2014 Prius c
    Is there any safety nets in place by Toyota I wonder?
    That is a wonderful idea.
    But I wonder at what point is it stuck in limbo....how low can you go?
    just curious:whistle:
  14. bisco
    52,390
    safety nets for a car that is functioning within parameters?
  15. john1701a
    john1701a Prius Guru
    12,833
    5,310
    58
    My first car had 2 cylinders (of 4) delivering less than 50% of normal compression. That made the under-powered car struggle even more when accelerating and climbing hills. It was just considered a natural part of vehicle aging. How much has that changed decades later? How precise is the language of engine warranties?
    Data Daedalus and Christi1992 like this.
  16. Christi1992
    Germany
    2013 Prius Plug-in
    Haven't been that low yet, would try it next time. Going low enough would light up Christmas lights in dash, and disable power steering and all other electronic systems (unable to drive).. Worst would be engine won't be able to kick in since the MG1 won't have enough power to start the ICE. Unless you plug it in and charge the battery up, and clear the codes. Doing this on a non plug in would be a visit to the dealer I guess.
  17. Christi1992
    Germany
    2013 Prius Plug-in
    That sound like manifold issue. My previous 2010 prius had same type of symptoms, engine loosing power when accelerating and so on. For me the solution where to clean up the intake manifold. Which I also recently did on my current phv to avoid issues in future.
    Regarding Warrenty, Toyota here in Germany wouldn't service it on their own cost. That was the reason I choose to do it on my own.
    nesoccer and bisco like this.
  18. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    You have a battery problem. Or bad sensor
    I would open it, measure it and maybe manually balance the cell group
  19. Ohid
    Ohid Member
    157
    Dhaka, Bangladesh
    2015 Prius Alpha
    I am using JDM Prius Alpha which also have Li-ion battery. It is now at 97k km and 2015 model year. My Li-ion battery also showed Delta SOC 5.5%-6.0% and Voltage difference are under 0.25V. But, in my case top up charging is not possible. It is not plug-ins.
    What is the present condition of your plug-ins Li-ion battery? Does it perform flawlessly?
    Should I be worried for my Li-ion battery?
    Thanks.
  20. bisco
    52,390
    i wouldn't worry about it, but if you want to, you could look for a grid charger for li-on batteries, or disassemble it and do each module with a hobby charger
    Ohid likes this.
