Battery Upgrade, Longer EV Range in my Gen 3 2013 Prius
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by black_jmyntrn, Jul 13, 2022.
  1. black_jmyntrn
    black_jmyntrn Senior Member
    1,289
    336
    2013 Prius Plug-in
    Humor me here, say I found a way to increase my EV range, using another battery, how should I capture proof of this so that when I post online folks can't say its movie magic?
    So far its with another OEM Toyota Battery, I'm sure one of you smart folks know which vehicle it came from... the next step on the roadmap is to have a Lithium Deep Cycle Battery made, I want 100+ miles EV range and that's my goal.
    Would you believe me if I said I've also been able to modify the ECU of the Plugin Prius to not only get longer range but also more horsepower out of the Prius? So far all the work has been on a 2013 Plugin.
    [below: this is the 2.0l Lexus UX250h motor, the M20A-FXS going into my PIP]
  2. 2010moneypit?
    2010moneypit? Active Member
    314
    122
    Beaumont ca
    Nice. Lots of mods.
    black_jmyntrn likes this.
    49,378
    i don't believe a word of it :p
  4. black_jmyntrn
    1,289
    336
    2013 Prius Plug-in
    Ha! Wel, the Japan spec ECU I'm using to determine which values can be changed was my first step in the right direction.
  5. Leadfoot J. McCoalroller
    7,135
    6,683
    Pennsylvania
    2018 Prius c
    I got into ECU hacking on my old Subaru, so I know it's possible. And I drove some really fun results. I also know it's hard to get it right and easy to get it wrong. I don't play in that space any more- lots of respect to those who still do!
    N.J.PRIUS likes this.
  6. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    The best way I would say is an uninterrupted video of the drive. Two camera views, a la YouTube auto reviews. One of the center dash with the energy meter and the HSI. And one behind the left shoulder of the driver showing the road ahead and the steering wheel.
    For hp, I need to see the dyno charts.
    It'll only be a 25 minute video? Yeah, I'd be very skeptical as I would think it'll cost more to upgrade the 2013 than to purchase a used Prime.
    2010moneypit? likes this.
  7. black_jmyntrn
    1,289
    336
    2013 Prius Plug-in
    multiple cameras!! 10-4! and dyno, understood!
    cost more on which part? used parts are cheap!
  8. black_jmyntrn
    1,289
    336
    2013 Prius Plug-in
    the japen spec phv ecu I have makes it easier... able to compare the two... now need a ct250 ecu to compare.
  9. le baguette
    le baguette New Member
    australia
    2013 Prius Plug-in
    i-Tech
    Interesting. I drive a Japanese import PIP and be interested to know how u did it
  10. black_jmyntrn
    1,289
    336
    2013 Prius Plug-in
    how many miles do you get on a full charge? id be curious to know the part number of the ecu in the engine bay...
