Battery upgrade?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Jerry Liebler, Nov 26, 2014.
  1. Jerry Liebler
    Jerry Liebler Member
    177
    85
    Science Hill Kentucky
    2013 Prius Plug-in
    I happened to see this listing on Ebay: Toyota Prius Plug in Hatchback 4 Door | eBay
    The listing claims to have changed the OEM HV battery from 4.4kw to 10 kw.
    Does anyone know if this actually works? I called the lister, he said he used part of a volt pack, retaining the liquid cooling & the luggage space remains as stock. He must have relocated the charger & done a good bit of metal fab. The lister claims to have used the original BMS and made no software changes & it runs but he hasn't done real testing. FWIW the volt pack is 45 AH, stock is 21AH so EV range should be a bit better than doubled. But I recall that when PLUG-IN SUPPLY tried simply paralleling added battery capacity the PIP's computer(s) simply ignored the added capacity resulting in no EV range gain.
  2. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    "Hasn't done any real testing."
    I bet that is true.
    retired4999 likes this.
    49,434
    i'll give him credit for honesty. sounds like a disaster waiting to happen.:eek:
  4. GregP507
    GregP507 Senior Member
    3,002
    480
    He's probably trying to sell it before the explosion happens.
    :eek:
