Battery Vent runs loud, battery never discharges, slow/jerky acceleratio
Discussion in 'Gen 2 Prius Main Forum' started by ironcross90, Feb 12, 2019.
  1. ironcross90
    ironcross90 Junior Member
    Vermont
    Hi all,
    My 2008 Gen 2 has about 155,000 miles on it. Recently, I had the dash light up (including the red triangle). I have also noticed that the battery vent fan has been running loudly pretty consistently and that I am getting some odd performance (jerky/slow starts and less power on the uphills).
    That said, I am seeing that the hybrid battery seems to NEVER discharge. This is surprising, as before these issues came up, I would notice the hybrid battery charge decreasing to only a few bars at the tops of long uphills (I drive consistently through the mountains). This is the first time in 6 years of driving two different gen 2s that I have seen the hybrid battery not discharging down more than a bar or so.
    Thoughts? It feels like this could be a traction battery failure, but the fact that my gas mileage hasn't decreased significantly (maybe down 2-3 mpg from before), leads me to believe that it must still be doing something....
  2. kens97uber171
    kens97uber171 Active Member
    177
    133
    US
    There are three temperature sensors inside the battery pack, there is also an intake air temperature for that battery pack cooling fan.
    if one of those sensors has failed the car could think that the battery is too hot, and run the fan more. Also when the car thinks the battery is too hot or too cold it will limit charging and discharging. So that may be why you don't see the battery level going down. There are several apps you can use. Hybrid assistant is the one I use. Primarily because I live in a very hot climate. And that particular app can override the car and turn on the cooling fan at a set temperature. But it will tell you the temperatures of most of the system's battery inverter engine and mg1 I believe.
    Doctor Prius is another one that may give you some information. That gives more detailed information about the battery, and thirdly would be torque, which can also tell you I believe all three individual temperature sensors and the intake air temperature.
    All three of those apps have free versions..
    and even if you purchase them they're not that expensive. You will need a Bluetooth OBD2 device that talks to the car and sends the data to your phone or tablet.
    TomB985 and jerrymildred like this.
  3. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    Have you cleaned the hv battery fan?
    jerrymildred and kens97uber171 like this.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    Ken's guess makes sense to me, but without reading the codes, it's just a guess. The codes will save you untold weeks and thousands of dollars of expensive guesswork.
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    I have seen battery failure similar to this. Module failure causes the engine to run continuously, overcharging the remaining good modules, so overall battery voltage is at a high state, but the battery itself is only as good as it's weakest module. What are the bars showing first thing in the morning after the car has sat overnight? Even better would be one of the many apps available that can display individual block voltages. A significant module failure will show itself after an overnight period.
    As Jerry said, the codes will tell the story....................
    jerrymildred likes this.
  6. ericbecky
    ericbecky Hybrid Battery Hero
    4,381
    3,242
    Madison, Wisconsin
    Certainly sounds like a failed/shorted portion of the High Voltage Battery.
    Plan on spending around $2,500 if you have someone else install a NEW pack for you.
    While they are in there make sure that they clean battery fan as well.
    Don't be fooled by ads promoting drastically lower prices (We Fix Hybrid Batteries for $500!!!!)
    Those are USED batteries and will never last as long as a NEW battery.
    You definitely get what you pay for when it comes to batteries.
    If you are a tinkerer you may be able to buy a NEW battery from your local Toyota parts department.
    There are some specialized tools you will want to purchase for safety and to properly do the job.
    Part will likely cost somewhere around $2,000?
  7. Lwerewolf
    Lwerewolf Junior Member
    Sofia
    p0a80 or some other HV battery-related code is set. Hybrid system is in failsafe, making sure that the pack has enough charge to start the ICE and that's about it. Current from and to the battery is very limited.
    You may or may not have a shorted module, but if the code is set, one or more are about to become such anyways (sub-capacity cell in a module, etc).
    Prepare for battery work.
    If you don't do much stop and go traffic, the MPG shouldn't be affected much - the engine is still running the Atkinson cycle, and the slow throttle response probably makes you drive smoother :)
  8. kens97uber171
    177
    133
    US
    Another alternative is to find out what modules are bad, take the battery out on stack it and replace it with modules you can purchase on eBay for about 50 bucks. I would get three of them, usually if one module fails the one that is paired with ends up being damaged also. But you can find out this information with some of those apps, doctor Prius will show voltage and resistance on the blocks which is a pair of modules. I believe it also has some built-in tests that you can perform to check battery capacity. But you might not want to do that if the battery is suspect and stress it even further. one of their possibility is that the bus bars have become corroded that connect up the modules to each other. That can cause a high resistance between modules and set a code. you could probably clean the bus bars without taking the battery out of the car. But you want to make damn sure you know what you're doing and how to make the battery safe in order to work on it. It isn't that difficult friend and I have done this procedure a couple of times now on his 2006 Prius. Had a module fail and then a few months later another module failed. but you can certainly continue to repair it I'll hell of a lot cheaper than it would cost you to buy a new battery. I'm not sure that I would invest $2,000 in a car of this age, when you did spend an hour getting the battery out another hour just assembling the battery and repair it for a hundred fifty bucks or so. You can do that several times and still be well worth it financially. And once you have a stable battery Doctor Prius can test the battery for capacity and you can get a pretty good idea if the battery is going to last you a while. It's never a guarantee. there are plenty of videos on YouTube on how to take the battery out and disassemble it and also how to clean the bus bars. They're just brass links that need to be removed cleaned and put back in. If you live in a climate that's very humid or salty this is more of an issue in those areas.
    George W and Andyprius1 like this.
  9. Lwerewolf
    Sofia
    You swap one "bad" module for another, and the rest will come soon, as has been discussed here a ton of times. Search the forum for whack-a-mole :)
    Long term DIY repair is possible, but requires:
    -A source of good modules ("holds charge" is not enough - must be of adequate capacity).
    -Hobby chargers and/or a grid charger & discharger.
    -Time.
    You can read up on rehydrating the pack as well, a few threads here and on greenhybrid (afaik). Even more time-consuming, and you'd better have a hobby charger and a temperature-controlled environment.
    If you manage to rehydrate it properly, it >should< outlast a new OEM battery. I say "should" because then you're increasing the likelihood of other Ni-MH failure modes that are usually not experienced - can't give you any info about them, but I'd much rather have a shorted cell due to water evaporation and cell meltdown (electrolyte deposits on plates, less surface area, lalala… read up), than an open cell (resp. circuit since they're linked in sequence) and being stranded. Still, this is speculation on my end.
    If you just do the regular "proper" DIY, it still won't be better than a new battery.
    If you just swap out the failed modules, you'll have a battery that's only as good as the next weakest module, and only until that module fails as well.
    New batteries from 2k1toaster (cylindrical cells) are $1600 without install, read through his threads before you decide that you want to go down that route. New battery from dealership - no clue in the US ($4k?), significantly less in the EU for whatever reason. (EDIT: look below, I stand corrected)
    #9 Lwerewolf, Feb 13, 2019
    Andyprius1 likes this.
  10. ericbecky
    4,381
    3,242
    Madison, Wisconsin
    In the US, retail price at the counter is like in the $2,100 range.
    Yes, if you are willing to invest many hours of time, you can pitter away at replacing individual modules. Heck, I'll sell them to you for $50 of you want.
    But this is not a long terms fix.
    You are just kicking the problem down the road. And in the meantime you may have an unreliable vehicle.
    As others have mentioned, if one fails, others will follow in the coming weeks/months.
    And each time you replace module you are adding more variability to your pack. The Prius does not like variability. It likes thing to be the same.
    You can combat this variability by purchasing charging/discharging equipment. And spending even more time fussing with the battery pack.
    If all this time and effort and unpredictability in your car worth the savings? Only you can decide that.
    For a single guy who has a lotlof free time, can walk to work as needed or has another car. Maybe it is worth it.
    For a guy with kids that need to be driven to school/childcare, has a job that he needs to be in time, and only one car.. maybe all this fussing is not worth it.
    Lwerewolf likes this.
  11. Lwerewolf
    Sofia
    I guess I'm way behind on US prices, sorry for posting so much confusion lately. Still wondering why lexus dealers can charge $7k ^_^.
    One thing about the charge/discharge - from what I've read if the pack is far gone, it can maintain it... but water has evaporated regardless and crystalline deposits form faster, therefore needing cycling more often, etc. Maintaining a new pack this way sounds like a better idea to me - breaking down deposits to keep temperatures in line.
  12. kens97uber171
    177
    133
    US
    I don't know my friend has a 2006, swapped in a couple of cells, end up having to swap 2 more just as you guys have said. But since then he's put 40 or 50 thousand miles on that pack.
    I think it all depends upon how much time you want to spend and how much money you want to spend. I don't know that I would put $2,000 into a 10 year old car. I can buy a lot of $50 modules and spend a 2- 3 hours fixing it. It all depends on what you're using the car for I guess. but with the apps that are available you can get a pretty good idea of how balanced the cells are and if the pack is healthy overall. Doctor Prius will do a battery capacity test, it can tell you what the resistance is across each block and the voltage on that block..
    I guess it just depends upon your priorities, how handy you are, and what you're going to use the vehicle for.
    I personally drive it 2008, it currently has 273,000 on it still running on the original pack still showing 55% of capacity when I test it. I put 55,000 miles on it last year alone. Obviously I bought it used.. with about 200k on it.
    So far my only failure has been the brake accumulator pump. Which I bought at a salvage yard and replace myself.
    I think if you're not handy with cars, you're best off to buy a newer one with a warranty. Or quite frankly don't buy a hybrid if you're going to stay with an older model car you're probably better off with a Corolla. Still gets decent mileage and eliminates a lot of the issues that age causes on a hybrid.
  13. Lwerewolf
    Sofia
    That's one experience.
    So you're putting some sort of cap on repair costs/things worth doing solely based on the age of the car, regardless of what the repair is or what the car is?
    Russian roulette, whack-a-mole, however you want to call it. You can probably bring down the work time to an hour or so if you really want to, but you're still blindly changing clearly failed modules with modules of unknown capacity, never mind the condition of the existing modules in the car.
    Buy an iMax b6 or whatever ni-mh hobby charger that you can program charge/discharge rates of, and you've got the basic equipment to test all modules and make better guesses... but it takes far longer than 2-3 hours. You're still left with the problem of how good are those $50 modules, unless you decide to rehydrate.
    dr Prius can approximate the per-block capacity. This is 12 cells in sequence. Read up on coulomb counting, and on ni-mh's voltage output depending on its SOC. Combine that with the fact that the car tries to keep the modules between 40 and 80% charge.
    So yes, you can approximate capacity, and which blocks are better than the rest (most likey a V-shape). Cell-level balance? Nope.
    Speculated 55% capacity. Yes there are many reports of Toyota/lexus hybrids running past 500k miles on original traction batteries. On the other hand, the ones that start to fail usually have quite a few more modules on the way of failing. Failed module usually means melted/internally shorted cell. Dumb (not entirely correct) explanation - you lose capacity due to losing electrolyte and due to crystalline formations in the cell. One happens because of heat and venting of the water component, which might accelerate two (less water to hold the chemistry). Two causes heat due to less surface area for the current to pass through, leading to one. One can be reversed by rehydration, two can (almost completely, apparently) be reversed by a combination of deep charges, deep discharges and temperature. So as a cell loses capacity, it tends to heat up more, accelerating the process. It also heats up the surrounding cells and modules. The modules in the middle of the pack tend to run hotter. Guess what happens :)
    ...or just get one with a failed traction battery, spend $2k on it and enjoy the benefits. Mileage is not the only reason to go hybrid. Or get an early 1zz-fe corolla and run it on dyno so that the piston return holes clog (if they haven't already) ;)
  14. ironcross90
    Vermont
    Thanks for the varied responses, all.
    I got an OBD bluetooth reader. I did see some voltage difference on cell 7 of the HV battery v. the other cells. The code that I pulled (P3017) indicates that cell is weak.
    That being said, when I cleared the code, I immediately heard the battery fan stop running and the engine turn off (this was the first time the engine had turned off since the codes came up a couple of weeks ago.) After driving it a bit, the voltage looked normal across all the cells. So far, I have driven it a few days and nothing has come back on. The performance has returned to normal.
    So, I reckon that the HV battery may indeed be on the way out, but the code itself caused the problem with the fan running and the battery not discharging?
    Also, any reason that I shoudn't just drive this guy into the ground? Even if the traction battery fails, is the car still operable around town?
    Thanks!
  15. john1701a
    john1701a Prius Guru
    12,797
    5,280
    57
    You'll see the code get triggered more often as time progresses. Now is your opportunity to weigh options.
  16. ericbecky
    4,381
    3,242
    Madison, Wisconsin
    It's all fun and games until something catastrophic happens. Like the modules shorting out, bursting and spraying the interior with a nice film coating of electrolyte. IsIthis common? Nope. Have I seen this happen? Yup.
    Hopefully you can see the data live and can tell when you are getting to the point of no return.
    If you are replacing a module, buy a couple now so that you are prepared. Easier to run out and get parts when you have a (semi) operable vehicle.
    Clearing the code does not really fix anything.
    Actually leaving the code set may help somewhat protect the battery. As opposed to clearing it and allowing the battery to get pummeled.
    Skibob likes this.
  17. kens97uber171
    177
    133
    US
    Lwerewolf...
    You have some valid information, and many of the things you said are correct..
    On the other hand I've been working on cars longer than you've been alive... All makes, all models.
    That would make me relatively proficient when it comes to working on cars.
    I drive 55,000 miles a year as does my friend with the 2006 Prius.
    we have the charger you're talking about, and used it correctly to test capacity on the new cells that we bought and all of the ones that were already in the pack, before we put in the new modules. Also if you purchase the modules from a reputable source. You're not likely to have a problem with them.
    we ended up doing the job twice, because we replaced two, and then a different pair of modules went bad. Since replacing those he's had no further problems.
    My point on spending $2,000 on a 10 year old car is not just about the age.
    You have to decide if it's a smart financial decision to spend $2,000 on a 10 year old car that could possibly have other major mechanical repairs that will come up especially if it's a high-mileage car or has any body issues.. rust etc.
    That's something each individual has to decide depending on the particular circumstances, and what their usage is going to be and what there options are on repairs.. DIY or dealer.
    My friend and I got a smoking deal on both of our cars.
    Bought the cars for $1000 each,
    And spent about $800 on each to get them roadworthy. 12 volt battery on each, brakes, tires, dash cluster on his, brake accumulator pump on mine.
    I have put about 60,000 miles on mine, my friend has put about 80,000 miles on his in the last year and half.
    because we have so little invested in the vehicle, we can afford to do major repairs and still be ahead of the game financially, especially since we have the ability to do just about any repair ourselves.
    not everyone is in that situation, or has the mechanical ability or tools to do that kind of work. So again that's something you have to decide when choosing to do repairs or not.
    the other thing that you have to factor in is how much do you save by owning the Prius? I drive 55,000 miles a year. So getting 47 miles per gallon save me significant money. But if you only drive 5000 miles a year you aren't saving that much but yet still have all of the risks associated with hybrid systems. So you might be better off to just buy Toyota Corolla or Honda Civic Etc. Because you aren't going to save that much money when it comes to gas expenses.
    You have to run the numbers and decide what is best for you..
    Skibob and Raytheeagle like this.
  18. jarrad reddick
    jarrad reddick Junior Member
    atlanta
    someone mentioned leaving the code might protect the battery as opposed to clearing it. ouch. I'm clearing codes every 2 minutes (3 gen2 prius's all have the same issue; I'm just trying to find someone with the skill AND time to help me get this done). But are there any threads on the topic of clearing vs keeping and driving with the triangle??
    @ericbecky
