Battery
Discussion in 'Gen 2 Prius Main Forum' started by lsimnick, Oct 11, 2005.
  1. lsimnick
    lsimnick New Member
    I just received my '05 Prius three days ago, and on the display, the battery never showed to be fully charged. The close it ever came to a full charge, was one bar reading away, then it went back down. It has never discharged below the half way mark. Is this normal? I only have 160 miles on the odometer.
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    Totally normal. You'll eventually see all green (top 2 bars) and eventually see at least down to two pink bars. But even when all green the actual total state of charge (SOC) is only ~80% and even when it's down to 1 pink bar the SOC is still at least 40%.
    The computer tries very hard to keep it closer to the middle/blue bar range to preserve the life of the battery only going higher or lower when it must.
  3. aaf709
    3,862
    2022 Prius Prime
    I've seen it at 100% a couple of times, but mainly after going down a long hill. It drops down pretty quickly after that.
  4. Tideland Prius
    16,151
    8 bars isn't 100%, it's only 80% true SOC. Evan's picture helps.
  5. efusco
    19,891
    1,192
    Nixa, MO
    Except my picture's gone?!
    It can be seen at this link:
    http://www.pbase.com/efusco/image/40124005
  6. greg4wv
    greg4wv New Member
    25
    Fayetteville, WV
    Evan -- your picture came back when I right-clicked and did the Show Picture option. Maybe PBase was busy?
    I see the full eight bars almost daily, as I have frequent ups and downs -- and some fairly long 2 - 4 mile downhills that I hit on a regular basis. I have only seen the pink bars (two or less?) maybe once or twice.
  7. Maytrix
    Maytrix Member
    742
    Marlborough, Mass
    [vent]
    When there are 8 bars on the display and all 8 bars are full, then it's 100% full. So, it's feasible to say, I've seen it at 100% a few times.
    I've seen so many posts where people nit pick about this when it really doesn't matter in context of the question. It was obvious the original post was talking about the bars showing 100%...
    [/vent]
  8. efusco
    19,891
    1,192
    Nixa, MO
    I can see how that might be frustrating to you, but equally frustrating for some of us is the misconceptions about what that battery indicator means.
    The top end isn't as big a deal, but people come here harried that their battery was 'almost drained completely' and they frantically shut down their automobile before it drained completely then trembled with fear not knowing if everything was ok or not, etc etc.
    I think it helps to dispel some of those misconceptions...esp. to someone who only has 160 mile on their car and clearly doesn't understand exactly what is being represented on the display or why it behaves the way it does.
  9. Tideland Prius
    16,151
    I know but I wanted to make sure that they knew. We don't want them to panic when they see 1 or 2 bars thinking that they're gonna be stranded because there's only 15% charge left or something like that.
  10. Maytrix
    Maytrix Member
    742
    Marlborough, Mass
    True, and while my post was directed at you, it was also directed at all the other times I see people state that :lol:
  11. Tideland Prius
    16,151
