Beep when braking
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mrstop, Jul 4, 2018.
  1. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
    Lately, when coming to a stop my car has started beeping at me. If I pay attention to the display, a message flashes but goes out too quickly to read. I checked the engine oil level and it is full.
    Any ideas what might be causing the car to beep at me?
    51,140
    maybe a bad brake actuator. check the brake fluid level.
    Raytheeagle likes this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    Is this intermittent or every time you come to a stop?
    Anyone ridden in the car and tried to help read the message?
    Is it for abrupt stops only?
    Have a code reader that might be able to help?
  4. Grit
    Grit Senior Member
    6,450
    4,186
    Wilkes Land
    Door or hatch not closed all the way?
    FuelMiser and Raytheeagle like this.
  5. ASRDogman
    ASRDogman Senior Member
    7,232
    3,774
    Use a camcorder and record it. Then you can play it back in slow motion or frame by frame and see what it says.
    jerrymildred and Raytheeagle like this.
  6. bisco
    51,140
    how many miles on her?
  7. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    check your 12v battery
  8. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
    I checked for codes with my OBDII reader and there wasn't anything showing. It happens intermittently at normal stops. I need to play some more to see if I can replicate circumstances to trigger it. Good idea to film and play back in slow motion as it's too quick for even focused passengers to read.
    70,000 miles on the car. Brake fluid is about 1/4" down from full.
    The car is still the original 12V battery. MPG has dropped quite a bit over the past 6-months so I thought the battery might be a possibility (Although the drop might be more attributable to my daughter and wife driving it more (and on short trips)). I took a quick read of the battery voltage this afternoon and the battery was surprisingly at 12.8V with everything off. I'm going to measure the voltage in the AM after it has sat overnight to check the battery again.
  9. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
  10. fuzzy1
    10,335
    By any chance, might you be pressing hard enough to activate the Hill Holder feature (Hill Start Assist Control, or HAC)?
  11. douglasjre
    douglasjre Senior Member
    2,094
    701
    Null, NL
  12. Kate M
    Kate M Junior Member
    64
    Hello, was this ever resolved?
    I just bought a 2013 Prius Two and noticed the same issue.
    Inconsistent beep when I come to a stop sign.
    Quite worried now, as this is a used car and in otherwise great condition.
    thanks
  13. Kate M
    64
    Actually, just listened again, and it’s more like a high-pitched hum that lasts one second. Heard it also when stopping in reverse.
  14. ChapmanF
    17,326
    There is a little electric pump that can run occasionally when you use the brakes. Usually not every single time, typically every few times. You may also hear it when you open the driver door to get in when the car has been parked a good while.
    In any case, it's easy to make that pump run and familiarize yourself with what it sounds like. You can just sit parked and apply and release the brakes repeatedly. Every so many times, you will hear the little buzz of the pump.
    Then, if you get familiar with that sound and it isn't the sound you mean in this thread, we can go back to the drawing board and try to figure this one out.
    Kate M likes this.
  15. douglasjre
    2,094
    701
    Null, NL
  16. Kate M
    64
    I'll go into my garage and try that. I drove a 2005 for 16 years so I'm familiar with what "normal" sounds like in that model.
  17. Kate M
    64
    It's a higher pitched, steady, but shorter-lasting sound than the pump.
  18. Kate M
    64
    What's that, please?
  19. ChapmanF
    17,326
    That's an on-board diagnostics code, but you would only have one if the car was reporting a problem, and if you had a way to read the code. I'm not gathering that that's your situation at this point.
    Does any dash light come on with the beep?
    Gen 3 has a "hill start assist" function. If you come to a stop with the brake, and then push the pedal a bit further, there will be a beep and the traction (squiggly road) light will come on. That means the brakes will hold for a couple seconds while you move your foot from the brake to the go pedal.
  20. Kate M
    64
    Thanks for explaining. No dash light indicator.
