Beep when door is opened?
Discussion in 'Gen 3 Prius Main Forum' started by nklb, Apr 17, 2013.
  1. nklb
    nklb Member
    111
    2012 Prius liftback 3 with solar roof
    I'm pretty sure this is new behavior the past week or so. Whenever I open the door, whether finishing a drive or entering the car from outside, the car beeps once as if it is trying to get my attention for something. This happens when the car is off (I always press the power button before opening the door)
    I do not see any warning lights or anything obviously wrong; what is the significance of this beep?
  2. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    Is your sunroof open?
  3. nklb
    nklb Member
    111
    No, the sunroof is closed (I even pressed the close button again to make sure it wasn't ajar)
  4. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    Is there another keyfob in the car ?
  5. andreyco
    andreyco Member
    91
    27
    Beep inside the car or outside the car?
  6. retired4999
    2,652
    625
    Eau Claire, Wi.
    Check hatch back door.
  7. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    223
    Nature coast, Florida
    Three Touring
    The beep is to warn you that the battery in your FOB is low. You may have inadvertantly had it engaged at some point and ran the battery down. Put that FOB far away from your car and switch to the other FOB and see if the beep stops...
    retired4999 and andreyco like this.
  8. nklb
    nklb Member
    111
    No other FOB in the car; rear hatch is closed.
    I'll investigate the possibility of the low battery when I get home from work today and report back. That would be annoying if so, as the car is brand new from October!
  9. nklb
    nklb Member
    111
    The car still beeps even with the other FOB (which has been unused sitting on a shelf since the car was taken home from the dealership)
    The beep is on the inside, and happens within a second of the door being opened.
  10. Eclipse1701d
    645
    223
    Three Touring
    I'm at a loss. That is the only reason I am aware of that the car will beep at you without displaying any other alerts... I am a very curious person and I find this quite vexing!
    However unlikely, due to the age of your vehicle, have you checked the 12volt to determine if it may be failing, prematurely?
  11. andreyco
    andreyco Member
    91
    27
    Everything I'm finding points to the moonroof being open (even slightly). Try opening and closing fully.
  12. p00kienrayray
    p00kienrayray Active Member
    720
    135
    Long Beach, CA
    It may be the sunroof. I had a 2012 Two and never heard that beep. Now that I have a Three w/sunroof, I've noticed it a couple times.
  13. p00kienrayray
    720
    135
    Long Beach, CA
    It's the sunroof. Just tested it now.
  14. nklb
    nklb Member
    111
    Okay, indeed it seems it was the sunroof. I opened it and then closed it again, and now the beeping has stopped.
    The sunroof was definitely closed though, I had even pressed the close button and it didn't close further, and drove through some pretty intense storms today without any leaks.
    Any idea why the car would think the roof was open when it clearly was not?
  15. andreyco
    andreyco Member
    91
    27
    Glad you got rid of the beep! As for why it wasn't sensing the sunroof being open...it happens! Electronics doesn't always behave the way we expect them to. The sensor that determines whether the roof is open or not may have malfunctioned, or it may be dirty. If you continue to experience the same problem in the future it's worth a trip to the dealer to try to get it taken care of while you're still under warranty.
  16. Eclipse1701d
    645
    223
    Three Touring
    Glad to hear you discovered the source! Now, we know of two reasons for the beep.
  17. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    What we need now is to get Toyota to convert these beeps to speech, E.g. "Sunroof open", "Door open", "Key in car" etc. it's not new technology, some vehicles already have this .
  18. Eclipse1701d
    645
    223
    Three Touring
    Like my '87 LeBaron use to say, "You're door is ajar!" I guess they lost the technology from ancient times...
  19. retired4999
    2,652
    625
    Eau Claire, Wi.
    But mine is a door not a jar?
  20. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    The buying public found the spoken warnings to be annoying beyond belief.
    If anyone had liked them they would have stayed.
