Beeping After Hard Bump
Discussion in 'Gen 2 Prius Main Forum' started by Banjoman, Jun 11, 2008.
  1. Banjoman
    Banjoman Member
    124
    Orange County, CA
    Yesterday I unintentionally drove over a curb onto the road. When the rear wheels hit the road, kinda hard, a loud beeping started inside the car that continued for at least 30 seconds. No warning lights came on. It sounded like the car was about to explode! Then the beeping stopped and everything was back to normal and has been since. Any ideas?:confused:
  2. Betelgeuse
    Betelgeuse Active Member
    1,460
    24
    New York, NY, USA
    Sounds like the VSC (Vehicle Stability Control) as I've heard it described on these forums. However, there should have been a flashing light accompanying the sound.
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    VSC was my first thought as well...but it shouldn't have lasted 30 seconds unless there was something bad wrong.
    I am interested if there were any dash lights or anything.
  4. gatsby_88
    gatsby_88 Junior Member
    Columbus, Ohio, USA
    Sounds more like the seat belt warning if it lasted 30 seconds. Did you have anything in the passenger seat that may have gone airborne when you hit the bump and then suddenly dropped into the seat with force, triggering the sensor as if someone had just sat down in it?
    There would have been the flashing passenger seat belt warning light along with the beeping, but it's far over to the right so you may not have noticed it.
  5. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    Intermittent beep or shrill, steady beep? The latter would
    possibly be a warning about loss of hydraulic pressure in the
    braking system. Can you see any damage/leaking under the car?
    _H*
