Beeping after start up & Door locking questions
Discussion in 'Gen 2 Prius Main Forum' started by Jackoar, Aug 21, 2017.
  1. Jackoar
    Jackoar Junior Member
    22
    Long beach Ca
    I have two questions here. I have an 06 gen 2 fully loaded. In other gen 2's i believe when you power on the car there are 3 or 4 beeps.. right when it starts. Mine doesnt do that. Also when I begin to drive the doors dont automatically lock when I begin to drive i'm not sure if its supposed to or not but I want to find out. Im just curious if maybe someone could have disabled those two things and if I can restore them some how.
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    My wife's '07 does a double chirp if the seatbelt is fastened. If it's not fastened, it will beep several time, iirc. I seem to remember that those are configurable. Easy with the Techstream software. Carrista also sells a phone app and an OBDII adapter. Lots and lots of threads on here about both.
    Someone will probably be along soon with more definitive info about if those can be changed.
    Raytheeagle likes this.
  3. Kenny94945
    Kenny94945 Active Member
    843
    418
    Sausalito
    2016 Prius v wagon
    Check your owner's manual.
    In my '16 V I recall there is menu to set automated door locking.
    Not sure on your other question.
  4. Jackoar
    22
    Long beach Ca
    thanks guys I will try techstream as I own a copy.
  5. 'LectroFuel
    'LectroFuel Senior Member
    880
    673
    San Juan Capistrano, CA
    Carista only has diagnostics for the gen 2 currently, no customizations.:(
