Beeping in Reverse.....
Discussion in 'Gen 3 Prius Main Forum' started by Miata Racer, Sep 26, 2012.
  1. Miata Racer
    Miata Racer Junior Member
    58
    St. Louis, MO
    Highly annoying - is there a way to turn off this "feature"??
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Yes. Two ways in fact. One - by your dealership. Two - by the use of a ODBII tool such as the ScanGauge II.
    Depending on your persuasive ability, you might be able to get your dealership to do it for free. Tell them it is indicated in the Owner's Manual and they should do it for free. Takes about 5-10 min.
  3. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    You can also use the ELMSCAN5 tool from Amazon which was under $30 when I got mine.
  4. fgp
    fgp Active Member
    503
    169
    daytona
    2023 Prius
    im still in the minority in that it confirms what the car is doing. i dont mind it. when i had my c for a short while it did not do it and i kind of missed it. however, it did not go to the dealership and demand that they add it. im not quite that nuts ...yet.:)
  5. our1vue
    our1vue Member
    313
    58
    NY
    xliderider,
    How do you know what to do with the elmscan5 to turn off the beep ? Is there a chart like the scangauge that tells
    you want to enter as parms ? Thanks
  6. Steve Gibson
    Steve Gibson Junior Member
    31
    Sunbelt Region of USA in TSS Edition
    After recently buying my new Prius, the beeping was driving me crazy. The dealership gladly adjusted it to the one beep mode for no charge. I opted for the one beep versus no beep so I know when Reverse engages...
    BTW I asked the salesman to ask the service department to do it at no charge - as the sales guy wants to keep you happy when you get the Toyota surveys etc... :)
  7. xliderider
    8,140
    3,277
    Honolulu, HI
    There is a long thread in this forum that a member posted a batch file they made that will specifically allow you to select the reverse beep and passenger seat belt parameters. Just download the file, unzip it, hook up your elmscan5 to the OBDII diagnostic port and run the batch file.
  8. PruisAz
    PruisAz Member
    140
    34
    Mesa, Az
    My first reaction when I heard it was that I thought a trash truck was going to back into me....
    I removed my using the Scan Guage. Just one beep heard when I put the auto in reverse. It'll work.
  9. Miata Racer
    58
    St. Louis, MO
    Thanks for the help - one beep will be fine.
