Beeping in reverse
Discussion in 'Gen 2 Prius Main Forum' started by Keath Bordeaux, Mar 22, 2025.
  1. Keath Bordeaux
    Keath Bordeaux New Member
    23
    What a goofy car these are in some ways! Don't get me wrong, there is a lot that I really do like about my 2005 that I've had seven months now! If it's going to make an obnoxious beeping sound when I'm backing up in reverese, it should be on the OUTSIDE of the car not the inside, what's the point to that? Anybody know how to disable that feature? Thanks.
  2. pasadena_commut
    pasadena_commut Senior Member
    2,801
    832
    Southern California
    If you obtain a copy of Techstream (search this forum for more information on that) there is an option to disable it. I think perhaps it only converts it from constant beeping to a single beep, but I may be mixing up the 2nd generation with the 3rd. I like the single beep mode, which announces it is in reverse if for some reason one has a brain fart and moves the lever the wrong way, but then doesn't keep beeping so that you can't hear much of anything else.
  3. Goodcitizen
    Goodcitizen Member
    75
    30
    Cali
    If you use Google you'll find a 'chicken dance' to disable it. You can also disable the seatbelt beep if you'd like.
    Here's the reverse beep disable technique. I just googled it
  4. Has Raf
    Has Raf Member
    180
    43
    Stoke-on-Trent, England
    Is there any way to do this with UK models?
  5. dolj
    dolj Senior Member
    8,549
    4,341
    Wellington, New Zealand
    Not that anyone has uncovered so far.
  6. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    464
    Leawood, KS
    I
    Only to pull the dashboard and cut the wire to the speaker...or add lead wires to it and install a switch
  7. Stu9
    Stu9 Junior Member
    84
    Near Mearns
    Yes it's bad that the UK can't do it. I tried 4 times yesterday but no.
  8. Mendel Leisk
    41,861
    I’d prefer the reverse beep to be replaced with something more specific, say “IN REVERSE, IN REVERSE, IN REVERSE…”. :)
  9. Stu9
    Stu9 Junior Member
    84
    Near Mearns
    I downloaded Dr Prius so will hopefully be able to turn it off.
  10. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    Third planet from the Sun
    Disabling is possible on Gen2 of the American market.
    For the European market, they came up with a way to reduce the volume of the sound of the squeak about the reverse gear.
    Sticky tape on the output of the speaker sound.
    It is written in detail how to do this in German.
    Rückfahrpiepser – Prius Wiki
  11. ald1stil1
    ald1stil1 New Member
    Italy
    I tried many ways to make it stop but even Toyota dealership says that it's impossible to mute it.
    Any suggestions for EU models?
  12. pasadena_commut
    2,801
    832
    Southern California
    Hmm. Some variation of this....
    Cut one speaker wire. Put a "usually closed" relay there, with the two speaker wire ends attached to the switching pins. Then find the wire which turns on the back up lights and use that to drive a circuit to power the relay. I'm assuming that using the back up light wire directly would be a bad idea because those sorts of circuits tend to be current limited and driving the relay might burn it out. If an optical relay was used it might be OK though, as those usually only draw tens of milliamps.
