Belly Scrapes
Discussion in 'Gen 2 Prius Main Forum' started by airportkid, Dec 19, 2005.
  1. airportkid
    airportkid Will Fly For Food
    2,191
    538
    San Francisco Bay Area CA
    Three months and 4000 miles into owning this fabulous car I did it again: scraped the belly on a the crown of a driveway that climbs up out of a parking lot and then drops abruptly down to meet the level road. I did it the first time about a month ago on another similar driveway. That first time I blamed the driveway: it did seem a bit steep. But having now had it happen twice in such a short time I have to wonder. In all the 400,000 miles I owned three Civics I never scraped the belly, nor in all the 140,000 miles I managed to get out of a low slung Saturn. But I've done it twice in 4000 miles and 3 months with the Prius.
    Anyone else out there winced when pulling up over the crown of a steep driveway and scraped the belly? Is the 14 inch wheel with the stock Integrity actually too small by half an inch or so?
    Mark Baird
    Alameda CA
  2. DocVijay
    DocVijay Active Member
    1,455
    Tampa, FL
    The Prius IS a very low car. Just one of the trade offs in the name of aerodynamics.
  3. Spunky
    Spunky New Member
    469
    Maybe this would make a good poll question.
    Haven't had a problem with bottoming out. But I never speed in or out of parking lots, either.
  4. galaxee
    galaxee mostly benevolent
    9,810
    465
    MD
    bottomed out twice in 8k miles. last week i hit a bad one and knocked the skid plates off. this car is very low, it has to be on your mind as you drive or you'll hit things.. :(
  5. Tideland Prius
    16,122
    Yup..
    bottomed out over humps with a full load of people in the back.
  6. DocVijay
    1,455
    Tampa, FL
    This is why I'm wary of getting the TRD coilovers. I don't want to lower this low car any more. I do drive over some speedbumps daily, and don't want to get stuck.
  7. Salsawonder
    Salsawonder New Member
    1,897
    47
    La Mesa California
    Surprised the heck out of me the first time it happened. I was turning around in this driveway and the belly just dragged across the surface. I have been driving a truck for so many years and the Prius seats are higher then some cars but the car itself definitely sits lower than you think. I also drag that front bib sometimes coming out of driveways or up some of our steeper streets here.
  8. windstrings
    windstrings Certified Prius Breeder
    6,280
    378
    Central Texas
    tires are 185/65R15, 14 inch would be even lower.
    Aerodynamics seem to always be best on cars that are really low... its a catch 22.
    You could have a 2005 Porsche Carrera GT Cabriolet and have even less clearance?
    http://www.theautochannel.com/newcardb/ccc...ars&titleid=326
  9. DocVijay
    1,455
    Tampa, FL
  10. windstrings
    6,280
    378
    Central Texas
    Ah..well let me think?..... humm... well if I could ah..... NO! :lol:
  11. DocVijay
    1,455
    Tampa, FL
    Well, I guess I just need another $410,000 and then I can trade up...
    BTW, there are two of them around here where I live, one black and one silver. Darn fine cars. Very easy to overlook the ground clearance thing.
  12. NuShrike
    NuShrike Active Member
    1,378
    People getting surprised by the "low" clearance.. are you coming for a vehicle with a higher clearance like say a SUV?
    I came from a Civic and clearance has been pretty much expected and the same.
  13. Tideland Prius
    16,122
    Nope. I came from a Camry. It has at least an inch less that's for sure but I rarely, if ever bottom out in a Camry. I've bottomed out at least 4 times with the Prius, most over humps, once over a ramp
  14. DocVijay
    1,455
    Tampa, FL
    I am coming froman SUV, and a lifted one at that. I have about 15 inches of ground clearance, as opposed to under 5 for the Prius. I REALLY need to adjust my driving.
  15. delrey
    delrey Member
    280
    SF Bay Area (East Bay)
    Well my last car was a Honda Accord - and the Prius low clearance drives me nuts sometimes. The other day I actually skipped going in to a Starbucks because it was too hard to park. The only open spaces were skinny & required tight turns to get in, and the turn took the front scraping over the adjacent curb. Argh!
    Also my driveway is a problem ... front end always scrapes unless I am super careful & back out at an angle. I guess I should fix the driveway - the car is a keeper ;-)
  16. AndyTiedye
    AndyTiedye New Member
    51
    There was the time I took the Prius to a rave out in the woods. I thought the road was paved all the way, but noooo.
    It did not do any damage to the Prius, but it is evident that this is what the Escape Hybrid is for.
  17. MNPrius
    MNPrius New Member
    177
    Minneapolis
    My driveway is also angle only but I scraped the cars with my mid-size sedans as well. I have noticed the lowness of the Prius though - plowing over a "snow chip" left by another car felt like I ripped up the entire bottom :eek:
  18. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    I agree in general that the Prius isn't really any more prone to scrapes than other cars with comparable clearances. If you're used to a higher clearance, yah, you can misunderestimate what you can handle.
    But, I think there are two issues with the Prius that might make it a little more prone to scrapes.
    1) Low "Attack Angle" - this is the angle incline you can approach before you scrape the bottom of the nose. If you notice, the real off-road SUVs often have the nose angled up, and even have angled skid plates right behind the front bumper. The Prius Air Dam is pretty low, and can scrape on driveways and parking curbs. But, I don't find this any more likely with the Prius than with, say, an old Trans-Am or any other low nosed car. Just something you have to learn. You can approach steep ramps at a slight angle to mitigate it.
    2) Longer Wheelbase - The Prius has a relatively long wheel base for a car of it's length. Though a Corolla or Civic may have the same absolute clearance, a longer wheelbase will lead to more belly rubs over humps and bumps.
    But, in the final analysis, I don't think it's particularly bad for what it is - a small car with low ground clearance.
  19. David
    David Member
    169
    Vero Beach, Florida
    We're developing a number of groves in Florida. I had to drive to a meeting at the far end of a grove path and went over a couple of rocks that I didn't see due to the tall grass. As I went over them I could feel them bend the floor boards up under my feet. didn't seem to do any damage but this has inspired me to buy a truck for trips to the job sites.
  20. windstrings
    6,280
    378
    Central Texas
    I wonder if stronger struts would help out?... prob make the ride stiffer, but alot of people have expressed how they would like more of a sportcar feel anyway.
    I think if they raise the nose it may kill aerodynamics as air catches in the airpockets under the car.
    Ideas:
    *Maybe we could mount a small cattle catcher!
    *Hydrolyics! with radar so the car will lift when it sees an obstacle coming!
    :lol:
    I wonder if other "high performace" cars that are low to the ground have similiar issues, or whether stiffer suspension helps?
    Does anyone notice if its when the shocks or struts "depress" like encountering a driveway that the bottom hits, or does it happen if the speed is slow?
