Benoulli effect lessened by window deflectors?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by GAGendel, Sep 11, 2006.
  1. GAGendel
    GAGendel Junior Member
    59
    New Jersey
    I really like to drive with the window open in nice weather. However, the Prius has a real bad behavior that causes a low frequency oscillation that hurts my ears. In order to reduce it I either have to put the window most of the way up or open up all windows.
    I was wondering if putting on the window deflectors would impact this behavior, possibly making it acceptable?
    Anyone with window deflectors care to comment?
  2. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    I've noticed that occasionlly in different cars with different window configurations... try cracking the back windows and inch or two, then put the drivers window where ever you want. It seems to aleviate the problems for me.
    Also, someone suggested it on here a while back, but for higher speeds when you don't necissarily want all that wind hitting you in the face, you can crack the two back and one front window a few inches for excelent airflow, and none of it in your face!
  3. MarinJohn
    MarinJohn Senior Member
    3,945
    304
    The deflectors do not eliminate (nor appreciably decrease) the effect.
  4. hyo silver
    hyo silver Awaaaaay
    15,261
    1,601
    off into the sunset
    I haven't driven a Prius without window deflectors, but I can assure you Bernoulli is still hard at work. Opening the windows only slightly reduces the effect, but doesn't eliminate it. Being able to open the windows a bit without letting the rain in is a nice feature.
