Best 2008 tires?
Discussion in 'Gen 2 Prius Main Forum' started by KCPetite1, Dec 22, 2025 at 1:23 PM.
  1. KCPetite1
    KCPetite1 New Member
    Friday
    I just had Pirelli Tires installed and don't like them. What you you recommend 185/65/15 or 195/65/15?
  2. priumium
    priumium Member
    258
    65
    Sweden
    2013 Prius Plug-in
  3. Mendel Leisk
    41,506
    185 i/65R15 is the Toyota spec'd tire; installing 195'65R15 will theoretically increase radius of the tire by 6.5 mm (~1/4"), which will have ramifications, such as drag increase, stability reduction, through off the odometer. All slight, but...
    It will increase ground clearance of course, again, a slight amount.
