Best aftermarket alternative to OEM halogen headlights?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by ekaziak1, Jun 1, 2023.
  1. ekaziak1
    ekaziak1 New Member
    Binghamton, NY
    Hello folks, I am a new member here, I bought 2007 prius base with 180k miles on it about a year ago. I use it mainly for commute, it is a great car. Recently, I have noticed that the headlight pattern looks a little weird (see the photo below) there is tons of glare from the right headlamp. The car was in accident, so the headlights were replaced, they might be of inferior quality to the stock ones. Now, I am thinking of buying new ones, any recommendations on aftermarket brands? I saw some from Eagle Eye, TYC, but there are no reviews. Did anyone have experience with aftermarket headlight for prius gen 2? What brand you ended up with?
  2. alftoy
    alftoy Senior Member
    1,130
    505
    Saskatchewan, Canada
    It's not the headlight assembly that gives the light, its the bulb inside. Also if car was in an accident the headlight aiming may be off.
  3. ekaziak1
    ekaziak1 New Member
    Binghamton, NY
    The bulb is of the right type, PhilipsRacing Vision GT200 H4. Indeed, the light coming from the bulb, but it is the reflector which aims the light and creates the pattern. If something is off with reflector, the pattern will be off. Some aftermarket manufacturers are not paying enough attention to the details of the reflector structure/geometry causing the pattern being dispersed. That's why I am asking if anyone had a positive experience with a particular brand.
