Best Aftermarket Headunit DVD player for Prius
Discussion in 'Gen 2 Prius Audio and Electronics' started by powerfularse, Oct 21, 2009.
  1. powerfularse
    powerfularse Junior Member
    Singapore
    Just like to share the new DVD player that I have just installed.
    With the following features:
    - Bluetooth
    - Steering wheel controls bulit-in
    - Ipod connections
    - With Toyota logo on it
    - Fits perfectly, its like a factory fitted one.
    Cheers:)
  2. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    That looks good but why did you describe it as the best aftermarket headunit DVD player? They are all a standard double DIN size and there are better looking units out there that likely also have better sound quality. Is there something special about this one and the way it mounts? :confused:
    Thanks for the pics!
  3. ursle
    ursle Gas miser
    1,049
    192
    NH
    Looks good, but
    who made it, where did you buy it,
    how long to install, did you upgrade your speakers,
    is it touch screen, is it available with navigation
  4. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,994
    Fort Lee, NJ
    I like to keep the steering wheel controls when I upgrade too. Is it a unit from another Toyota? Let us know the details.
  5. usbseawolf2000
    14,487
    2,994
    Fort Lee, NJ
    What do you recommend for a double DIN unit with GPS, Bluetooth and also compatible with steering wheel controls? Ipod connection would be a plus but not a deal breaker.
    Thanks in advance.
  6. powerfularse
    Singapore
    hi to me its the best cos it provide all the functions that i need and everything is so originally done. Yes it has gps navgiation And ipod function. Its so cool to connect the iphone via bluetooth and playing itunes at the same time
  7. powerfularse
    Singapore
    i have got the unit from a dealer in singapore. I have purchase the dash kit and modified the casing to fit the unit. Took half a day to get everthing installed. Comes with reverse camara as well. I couldnt find any alphines or pioneer units that fits so well
  8. usbseawolf2000
    14,487
    2,994
    Fort Lee, NJ
    The title said aftermarket head unit. Your dealer sells aftermarket unit? What is the model number? Did they use Scosche TA2103B double DIN kit?
  9. kaval
    kaval New Member
    Did you end up using the Scosche 2103B kit?
    What size player fits in the double din mount?
    Does the setup still preserve the undercompartment radio. It is hard to see from your photos. Do you have a larger photo?
    Thanks,
  10. Agape
    Agape Member
    378
    Ireland/Eire
    Hi Powerfularse, could you PM me details of this unit cost and where is available?
    Thanks!
  11. osofast10
    osofast10 New Member
    61
    Va
    more info please!!
  12. powerfularse
    Singapore
    Hi so sorry for the late reply. Yes I used the Scoshe kit and had to cut the side so that it cover the panel nicely. The size of the player was originally use to fit perfectly for Toyota corolla but the height of the player happens to fit prius as well, just that the sides will require the dash kit to cover it. And yes it preserve the under compartment storage space.
  13. osofast10
    61
    Va
    does anyone know what headunit that is?
  14. NeoPrius
    NeoPrius Member
    182
    32
    Maryland USA
    Probably one of many very interesting dvd units such as are available on sites like dhgate.com that are capable of displaying the Toyota logo. I looked extensively to see if I could find it, but I did not. The software on the screen looks similar to Eonon units. Maybe this is an older model that is no longer manufactured, or possibly particular to the Singapore region.
  15. bexunxula
    bexunxula New Member
    Georgia
    And what model is it?
