Best alignment specs for best mpg
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by plastermaster, Sep 2, 2014.
  1. plastermaster
    plastermaster Junior Member
    43
    Alameda
    Hi All, I bought a set of Michelin Energy Savers A/S last week and had an alignment done, and also all 4 struts (with 180K on them :O) replaced. My mpg dropped around 13 around town and about 4 for the hwy compared to the Conti pro contacts they replaced. I know the new tires have a break in but 13 mpg is beyond that from anything I have heard of. The alignment specs that they go by has a range and my new alignment is within, but not dead middle. I have also seen different specs (ranges) recommended for this car (07 non touring). But I am within any specs I have found. So I am wondering how much of a difference this can actually make. I really have not noticed much of a mileage drop in the past few sets of tires, all LRR, when I exclude the last 10K or so increase that I get from running them near bald. (No rain from april till Nov here so I squeeze a few miles beyond the wear bars if we're in the dry season.) So, with 180K of experience on this car and 3 other sets of tires, something seems really wrong here.
    Main question of this post is how much difference alignment makes within the spec tolerances, and then any other ideas that come to mind.
  2. Patrick Wong
    18,200
    6,479
    Check the tire air pressure and if necessary increase to 44/42 psi.
    The front toe-in should be exactly 0 while the rear toe-in should be slightly positive. If you have more rear toe-in that will help vehicle stability at the expense of additional drag.
  3. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    For smallest fuel consumption both toe and camber should be close to zero. But (in front wheel drive) rear toe in a slightest bit and front toe out a bit more. Front toe in and camber are adjustable (if camber needs more adjustment bolts may be needed). Rear is only adjustable by using shims which Toyota doesn’t recommend.
    49,727
    perhaps they left a door open and ran your 12 volt down.
  5. plastermaster
    43
    Alameda
    Would that cause a mpg drop after a couple hundred miles of recharge? I don't get the connection. I'm sure the hatch was up quite awhile to replace the rear struts.
    Front toe is 0 on the left and .01 on the right. and on the rear, .13 and .27 (could have done a little better there unless there was a problem)
    Front camber is neg .4 left and same on right which is pretty close to zero given the tolerance (as they show it) rear is neg 1.2 and 1.5
    On the rear tow the number is positive but it shows the measurement as behind the wheel and a little pic with the wheels toed out.
  6. valde3
    2,002
    745
    Finland
    Maybe best would be about 0.01 out. But difference maybe about 1/12 turn (guess) of an adjustment and I don’t think makes that big of an difference.
    Prius Shim Adjustment Procedure
    It’s also possible that even if numbers of adjustment are good machine wasn’t set up properly and really it’s very bad. Or that your increased consumption has nothing to do with wheel alignment.
    #6 valde3, Sep 3, 2014
  7. bisco
    49,727
    a depleted 12v causes the hv battery to try to charge it, causing the ice to run more, reducing mpg's. common symptom after having work done.
  8. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    Yes. There is also a potential for low voltage to cause the ECUs to reset and loose the learned driving parameters. That has been reported here often enough. It can take a while to relearn.
  9. Paul Schenck
    Paul Schenck Active Member
    523
    306
    Fresno, California
    Smart answers and good question. I'm going to say its a
    Tire issue. My 2005 has over 350,000 miles I've tweaked alignment to optimize handling tire wear and milage. Zero front and rear. Bald tires give the best milage. Overinflated ones wear the struts faster and the
    Tires too. Your harder tires ( higher road wear rating) are harder rubber giving less regeneration back)
    Glad to hear about the Michelin I was about to try them from Costco for a great price. I've had Pirelli from Americas tire
    And Toyo from LesSchwab. Do the same thing (10mpg less)
    If you go back and have them
    Check the static and dynamic balance I bet there is an issue. My best tires to date are Goodyear Integrity 185/65 R15 they are a little soft for the hot California Central Valley Summer though 35,000 miles on a set at 45mpg is good enough.
    iPhone ?
  10. plastermaster
    43
    Alameda
    Thanks to all for the info. its always great to learn more. Between the possibilities of break in and 12 battery, I'll give it some more time. I have heard mixed reviews on these favorite tires. Some people have really realized substantial mpg gains and others some major losses. Makes you wonder if something is going on at the factory. I do notice that the back zone (no power to or from the battery) is more touchy than before. Otherwise with all the hills and traffic in my area its hard to feel much of a difference.
  11. bisco
    49,727
    please keep us posted!(y)
  12. plastermaster
    43
    Alameda
    Just got back from a trip I often make so was able to do some better comparisons. I have about 500 miles on the new tires now. It seems there was either a major break in for these tires or else there was an issue with the ECU, but things are looking better than b4. There is one stretch of road where I come to a "40MPH ahead" sign and I hit that spot at 55mph and right when I get to the 40mph sign I used to be doing exactly 40. Now I am more like 41-42 over a couple tries. My last tank of gas gave me 360 miles and took 7.0 gal to fill. That comes to 51.4 mpg for the trip. This is about normal at best for the trip. I think though the ecu was still learning. All in all I don't think these tires are really cost effective, unles they continue to improve a lot, but I don't mind paying a little more in the long run for a couple mpg if I actually do realize a gain. In other words I don't mind paying a couple hundred more for a set of tires that are not the longest lasting and barely give more mpg as long as it gives me a LITTLE more mpg. Money isn't everything. Hey, the rubber on the new porche 918 hybrid cost over $700 each. For a couple hundred less per tire it would still do 0-60 in less than 3 seconds. But with its current tires it does 0-60 in 2.2 seconds AND you have the satisfaction of having the quickest production car on the planet. And since it cost between $800-900K whats a few hundred in tires? SO, anyway, my point is, if I can see mpgs in the 50's more often than I used to, I'll be happy. Still cant really hypermile in these tires though unless I'm going down hill. I keep them at 42psi. I could go a good bit higher and reduce the contact patch but I don't want to bald the center of the tires. I have yet to be able to keep the power train in the black zone without loosing speed unless I'm on a slight down hill grade.
  13. bisco
    49,727
    congrats!(y)
  14. dolj
    dolj Senior Member
    7,751
    3,925
    Wellington, New Zealand
    As it is a physical impossibility, I think you'll be waiting a long time to do this. :)
  15. plastermaster
    43
    Alameda
    [QUOTE="
    As it is a physical impossibility, I think you'll be waiting a long time to do this. :)[/QUOTE]
    We'll see about that after I install a set of those nifty bicycle tire adapters.:)
    Off topic a bit (but since I'm the OP) why is it that in brake mode I can cruise in the black Zone above 42 MPH?
    More update on the tires, my post above from my trip indicates that I do have less rolling resistance as per the coasting test, but for some reason now that I am back to around town driving, I am still averaging about 4-5 mpg less with these tires. This is not comparing with end of life on my last tires but rather my last tires over most of their life. I do feel the engine is working harder than b4 even though the car seems to roll better. I am wondering if the ECU has decided to use more ICE than it once did. But, also my hybrid battery is not more prone to being in a higher state of charge than before so if the ICE is being used more, its effort is going to the road and not the battery.
  16. bisco
    49,727
    not all lrr tyros are created the same, and it's possible that you've experienced some battery degradation.
  17. dolj
    dolj Senior Member
    7,751
    3,925
    The point I was making was focused on the "without loosing speed" bit. LRR tires are lower, not zero, resistance, so they will still slow down due to the resistance, just not as fast as the higher resistance of normal tires. Your observation "unless going down a slope" reinforces this as the slope cancels out the resistance to allow a constant speed.
    As I hardly ever use "B" mode, I can't say I've seen this behavior. I have seen it from time to time in "D" and all I can say is the HSD will do what the HSD does. Generally the HV battery has to be at the full end to see the is behavior.
    As already mentioned, maybe your HV battery has degraded a bit. If you have a long mountain descent in your area you could try climbing to the top and let your HV battery run down to 1 bar and then descend, in "D", holding a steady speed allowing the battery to fully charge to 8 bars. While climbing and descending high mountains on a regular basis can be hard on the system, it may be beneficial to do this once in a blue moon to exercise the battery a bit by doing a complete 40% (HSD empty) to 80% (HSD full) cycle. Just a though that came to mind. YMMV.
  18. plastermaster
    43
    Alameda
    With well over 1000 miles on these new tires, the mileage is still a puzzle. That little test I mentioned above, I performed again over the weekend. It still confirms that the car is rolling better than with the previous tires. I live in a hilly area and my HV battery seems to charge and discharge at the same rate as it has over the life of the car. The ICE (gas engine) burns about a qt of oil every 7-800 miles but this has been the case for at least 20K miles prior these new tires. The reason I bring this up is that the ICE is probably not as efficient as it once was and probably burns more fuel for the amount of work it performs. One thing I noticed this past weekend trip was that my last tank of gas gave me an indicated 50.1 mpg. however, it seems to have used 7.2 Gal in 304 miles. Thats about 42 mpg. Normally there has been no discrepancy between the display and the actual usage. With my last tires (even though these seem to roll better), filling up at the pump always came out to about 47 mpg as did the display. Bottom line: new tires and new struts has confused the car and made it use more gas even though it rolls better. This all happened immediately upon installation. Seems really strange. ITs not the end of the world though. I have 180,000 on this car so its at the point where I'm just glad it runs and hope to keep it running in some form or another for a few more years. At this point I wouldn't even look into any other car than a prius, although I like the Gen 2 better than the Gen 3. Another reason to hang on to what I have as long as I can.
  19. valde3
    2,002
    745
    Finland
    If happens again and doesn’t get canceled out by another tank try fuel system cleaner.
    #19 valde3, Oct 14, 2014
