1. The site is migrating to a new server this week, so there will likely be some downtime during that process. You can follow along here for updates.
Best bang for the buck mods for improving high speed handling?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by LVA, Aug 15, 2017.
  1. LVA
    LVA Junior Member
    Finland
    Hi mates!
    I have owned my Prius one year or so, and i'm quite happy with it. It is cheap to run and it is actually very good car to drive in gravel and snow. However, it does get little bit of unstable at higher speed, ie 70mph or so. My car is high mileage 2006 "Touring" and suspension components has been changed few years ago and they are fine i think.
    This is our 3rd car so i don't have that much money for these mods. So, what mods at the moment gives you the best bang for bucks to improve high speed handling? :)
  2. JimboPalmer
    12,461
    6,851
    Greenwood MS USA
  3. Lucifer
    Lucifer Senior Member
    1,014
    485
    Nh
    The front upper strut bar did the most for my 06'
    2nd was the underbody mid section stiffening plate
    3rd was the 17" 45 series tires and wheels
  4. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    743
    Delaware
    1. wider, better tires, 2. aftermarket corolla/matrix Progressive rear sway bar (or TRD), 3. front oem corolla sway bar. the sway bars make a tremendous difference on non-touring models; I expect they will help the touring too. a used front sway bar is cheap, but installation requires the engine cradle to be unbolted from the body, or the steering rack to be removed. its not a bad job if you know how to work on cars. rear sway bar is very easy to replace.
    Kevin_Denver and gta_ like this.
  5. LVA
    LVA Junior Member
    Finland
    I'm not sure about sway bars at the moment, because my car goes around corners reasonable well and body roll is not that much a problem. I'm sure they DO improve the handling for sure, but i will make those modifications later.
    What is the biggest reason for unstable high speed handling? Is it flexy chassis/body? Lucifer and Jimbo could be right. Next question is where i can buy those parts? I live in Europe and most of the ebay sellers postage fees are ridiculous.
  6. 69shovlhed
    2,170
    743
    Delaware
    what kind of tires do you have? when was the last time it had an alignment? over here Toyota put GY integrity tires on them and they are terrible. crap tires, out of alignment, body flex, weak suspension all contribute to lousy high speed handling. front strut tower brace will probably help, but they are kind of expensive, and the cheaper ones look so flimsy I doubt they do much.
  7. SFO
    SFO Senior Member
    5,245
    4,212
    Northern California
  8. Kevin_Denver
    Kevin_Denver Active Member
    581
    420
    Denver, CO
    These are the best recommendations. Completely agree.
    The biggest factor in the handling of the car is the tires' ability to make friction with the road. This is why the first upgrade is almost always tires. If you want better handling, go for a slightly wider (eg. 205/60R15) ultra high performance summer tire (easy reference is to use Tirerack.com and compare tires' ratings). Follow this with upgrading the sway bars.
    Stability on uneven surfaces is mostly affected by the suspension. Worn out struts can cause excessive bouncing. With tuning the car for a race track or otherwise, too high of a spring rate won't keep the tires on the road well and grip will be reduced on uneven surfaces. Too low of a spring rate and the car's weight will shift too much in corners, causing slip on the outside tires and reducing maximum cornering speed. A balance for the conditions must be found for the car.
    Also, a car in over-steer feels "unstable" to the average person. Research oversteer and understeer and their causes if you aren't already familiar.
  9. LVA
    LVA Junior Member
    Finland
    I have a two sets of tires. Winter tires are Bridgestone blizzaks and summer tires are Nokia Hakka Green. Both are premium brands and OK'ish tires. Standard Touring tire sizes. Suspension should be good, but i haven't check alingment in a while. So that's a good place to start! What is good air pressure for tires in Prius?
    I don't know, but thanks for posting. Need to check it out. Usually cheap parts are bad tho :D
    Problem for me is that it isn't stabile when you drive in highway with high speed. Front end does wander from side to side. Surface is usually as good as it gets. In bad roads my car is good to drive, ie snow and gravel and so on. I'm not sure about sway bars at the moment. They do improve handling when cornering, but i'm fine with that now.
    I own a mkIV Supra and i have modified it a little bit. The thing is, i always want to be a sure that i make the right mods so i don't fucked up the car. Prius is soooo different car with different problems so i need to think about it little bit. It feels that flexy body in Prius is my biggest problem.
    So:
    - Chechk the alignment (should be good tho, it goes straight when the speed is below 60mph)
    - Proper tire pressure (?)
    - Stiffen the body: stiffer mid plate and front strut brace
    What do you guys think about it?
  10. 69shovlhed
    2,170
    743
    Delaware
    the mounting brackets look kinda flimsy to me. they might be 1/4" thick high carbon steel, but for that price I doubt it. I have this one, which I got in trade for some diagnostic work for a priuschat member, so I don't know the brand, but the mounting brackets are very stout.
  11. 69shovlhed
    2,170
    743
    Delaware
    wandering could be incorrect toe-in adjustment; also snow tires aren't known for good dry handling. I don't know anything about nokia tires.
    I set my tires at 40psi and never noticed a problem with wandering. I would want to inspect the suspension for anything worn and get the alignment checked first. then look into a quality strut tower brace.
  12. SFO
    SFO Senior Member
    5,245
    4,212
    Northern California
    Almost looks like a BT brace, except for the green brackets.
    Do those brackets go full circle on top of the strut?
    How is the access to the fluids and relays?
  13. LVA
    LVA Junior Member
    Finland
    Well, it could be just me. Car is good for about 65mph, above that there is a little bit of wandering, steering feel is not good and it is not that stable anymore. I put 40 PSI for tires and it is a little bit better to drive now. I will check alignments and get some braces. In higher speeds there is a little bit of clonking noise from the rear hatch ie it feels that body does flex. Anyway, i will report back after i can get some parts installed.
    SFO likes this.
  14. 69shovlhed
    2,170
    743
    Delaware
    its raining now, or I'd go check to see, I think there are some rubber stops to keep the hatch from clunking. as much as I like these cars, they are kinda flimsy, so upgrading and adding braces is definitely a good idea.
  15. LVA
    LVA Junior Member
    Finland
    So, the question is which one offer more bang for buck:
    Tanabe 2 point Sustec front under brace
    http://www.andysautosport.com/products/tanabe_racing_development__TUB151F.html
    OR
    Tanabe Sustec Front Strut tower bar?
    http://www.andysautosport.com/products/tanabe_racing_development__TTB151F.html
    SFO likes this.
  16. 69shovlhed
    2,170
    743
    Delaware
    I would go for the strut tower bar, because I suspect the strut towers are more likely to flex than the undercarriage, which already has a big steel subframe bolted to it.
    SFO likes this.
  17. tazman
    tazman Junior Member
    58
    Kailua, HI
    I see you guys talking about the Corolla rear sway bar. Is there a specific year I should look for and can I use the front and rear bars from the same car?
  18. Kevin_Denver
    581
    420
    Denver, CO
    Search the forums for exact years, but you'll want the front bar from a junkyard Corolla/Matrix. The rear sway bar on these cars is only slightly thicker than the stock Prius rear sway bar, so you'll want a 22-26mm rear aftermarket sway bar instead. Progress and TRD are popular models.
    tazman likes this.
  19. 69shovlhed
    2,170
    743
    Delaware
    03- 08 definitely fit, but I think in fact the corolla bars are the same up to like '15. I got my front bar from ebay for $45. make sure you get the frame bushings and clamps with the bar too.
  20. tazman
    58
    Kailua, HI
    Thanks, that's exactly the info I was looking for.
Loading...
