Best Black Headlight Assembly for 2012?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by gertsprius, Feb 18, 2019.
  1. gertsprius
    gertsprius Member
    61
    36
    Dubois PA
    2024 Prius
    LE AWD-e
    I am looking for the best looking and best quality black headlight assemblies. I have been doing some research on here and other websites and find unclear answers. I love the look of the dual projector LED assemblies but they are a little on the expensive side. I would be okay with the normal projectors. I use LED lights and i want to know what the best option is for the cleanest output. TIA
  2. StarCaller
    StarCaller Senior Member
    1,279
    730
    Cedar Crest, NM, USA
    show us the ones you have to choose from /
    Pluggo likes this.
  3. gertsprius
    gertsprius Member
    61
    36
    Dubois PA
    2024 Prius
    LE AWD-e
    I have found these options here for the normal projector headlights. They are barely reviewed and the one with the 3 stars is probably off the table because there is a review for the water getting in the lens. I would like to get the led projectors with the dual projectors (which is the last picture) but the ones I found are upwards of $600 a piece.
  4. Mendel Leisk
    41,856
    Both sides for around $200? I would expect regular tinted sets in the same ballpark? Any catches?
    That's getting to cheap enough to rate consideration from owners with hazing up issues.
  5. gertsprius
    gertsprius Member
    61
    36
    Dubois PA
    2024 Prius
    LE AWD-e
    I found another set on CARiD I'll attach the picture of those. they have better reviews. I am also looking for the smoked taillights, I've seen people getting them on here from a place called Valenti. Where do you find those?
    Here is the image of the other headlights I found:
  6. James Powers
    James Powers Senior Member
    396
    555
    Bay Area
    The ones in the last pic, the LED's are OEM.. You can scrounge around Ebay and find them, you just need to make sure you get the harness and ballast also. You could always DIY your own using the baked method. I cant use an oven to cook a frozen pizza, so I havent tried this option... LMAO Pretty sure HybridPit will help you source the OEM LED's if you are willing for fork the cash. Prius G headlights are some of the cleanest, but those are JDM and hard to get at a reasonable price.
    gertsprius likes this.
