Best foglight bulb
Discussion in 'Gen 2 Prius Accessories & Modifications' started by nesss01, May 19, 2005.
  1. nesss01
    nesss01 New Member
    I'm contemplating replacing my foglight bulbs. My goal is to maximize the lumens output. I don't care about the color of the light.
    So the two best options seem to be either the Phillips vision plus or the new Hir bulbs.
    Any opinions on which is better?
    seth
  2. bobc
    bobc New Member
    361
    Durham, NH
    Hi Seth,
    I'd suggest that you check out this site and read the sections under 'fog lamps' and 'light color.'
    http://www.danielsternlighting.com/tech/li...hts/lights.html
    From my research, this is one of the more knowledgable people in the field.
    Also, check out under 'Sponsored Commercial Sites' on this site.
    FWIW, I went with Hir bulbs..
    Cheers,
  3. raybon
    raybon New Member
    36
    Boulder Creek, CA
    This thread talks about some nice halogen replacements for the fog lights.
    Halogens
    Glenn
  4. Begreen
    Begreen Member
    670
    Western WA state
    So what bulbs have people chosen as replacement fog light bulbs and why? How bad was it to change the bulb? What was the replacement procedure? I am looking at the Phillips All Weather, Polarg or the PIAA plasma Ion yellow bulb to achieve true fog lights (we get a lot of it) instead of the anemic stock units. I've driven fairly extensively in France, at times in the fog, and there really did seem to be less glare with the yellow fog lights.
    (Update: Danny fixed the link to halogens, it's working again.)
  5. talonts
    talonts VFAQman
    448
    69
    http://www.vfaq.net/mods/Lights.html
    FYI, on my 06, I only had to remove the outer bolt on each side to get my hand in there. It's a bit easier on your hands to remove both, but can easily be done just removing the outer bolt.
  6. Begreen
    Begreen Member
    670
    Western WA state
    Thanks. That's a big help. This even looks doable for a clutz like me.
  7. jbarnhart
    jbarnhart New Member
    629
    Santa Clara, CA
    DocVijay replaced his fogs with HID bulbs and ballasts. Check out his "mod" thread. I'm sold on this upgrade. It's more expensive than the HIR bulbs, but the brightness of the HID fogs make it worth the cost.
  8. Begreen
    Begreen Member
    670
    Western WA state
    Yes, I like the lower energy consumption too.
  9. Tideland Prius
    16,195
    Try the HiR bulbs on Sigma. There's one that has higher output AND lower operating temperature.
  10. OverTork
    OverTork Junior Member
    68
    Northville, MI
    I don't have an opinion on this yet because I'm just starting to look into the subject but here's an interesting link I came across.
    HIR
