Best Jump Starter?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by typesomethingwitty, Mar 29, 2013.
  1. typesomethingwitty
    typesomethingwitty New Member
    Do any of you have a favorite portable jump starter for your Prius? Maybe it's because I'm a worrier at heart, but I really want to keep a jump starter in the trunk in case my wife ever has an emergency where one would come in handy.
    Here are three I'm considering:
    1. The Energizer 84020 12V All-In-One Jump-Start System with Built-In Air Compressor and Power Inverter ($112.10 on Amazon). I like that you can keep it plugged in to charge indefinitely without worry. I also like the built-in air compressor in case tire pressure gets too low.
    2. The Stanley J5C09 500-Amp Jump Starter with Built-In Air Compressor ($79 on Amazon). I like the lower price, but I dislike its lack of float charging.
    3. The Jump-N-Carry JNC300XL 900 Peak Amp Ultraportable 12-Volt Jump Starter ($64.95 on Amazon). Small and light weight. No built-in air compressor, though. But, maybe that's a good thing. Maybe I'm better off having one jump starter that is only a jump starter and a separate air compressor that's only an air compressor. Might be better than a multitasker that (possibly) only does two things so-so. Thoughts?
    What do all of you use?
    Geo Dude and seckwielen like this.
  2. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
    I have never worried about carrying one. I have never had too much trouble with car batteries and find a set of jumper cables more reliable to get me home or to the parts store. The problem with jump starters is that they can be less reliable than your car battery.
    Steph1972 likes this.
  3. hb06
    hb06 Member
    550
    Huntington Beach, CA
    I have pretty much decided on the Energizer 400 84022 12V 350 Ca Jump-Start System. It is fairly compact, easy to use with good safe design for the cables. It also has an optional dock on the back for a 200 watt inverter. After seeing the other "all in ones", I prefer to keep the tire inflator separate. This unit is smaller and lighter than the Energizer All-in-One, seems more reliable and holds a charge well. This unit charges from the wall outlet. I have read it's not a good idea or efficient to charge these types of units from your car, so that's OK. I am keeping a Portable Tire Inflator, the Slime Digital 12V Tire Inflator in the car (8"x6"). It worked good enough for occasional use. Pumped up all Prius tires on 2 cars.
    Energizer 12-Volt 400 CA Emergency Jump Start Back Up System-84022 at The Home Depot#
  4. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    I disagree with the contention that portable jump starters are unreliable. Basically at the heart of all configurations of the tool they are basically just portable batteries. As long as they have been charged and are charged...they are going to work.
    Since this tool is presented in a lot of "Swiss Army Knife" type of configurations, my advice would be get the one that most fits your needs and desires. Then keep it charged and ready for those times you might need it. The only way a quality one, that is charged fails you, is if you have failed to keep it charged.
    Personally I like owning one....not only for the peace of mind owning one for any potential problems with MY vehicle that might arise, but even more for any problems with family, friends and co-workers vehicles that might arise.
    I own a Honda Fit, which basically has a motorcycle battery in it. So the idea of using it to provide someone else with a Jump Start? Does NOT appeal to me. Neither really does the idea of getting a jump start from anybody else if I needed one in the future.
    Owning one of those jump start "portable" power stations? Takes the awkwardness out of saying "No" when somebody asks me if I will give them a jump start. I can be helpful and a good Samaritan, without putting my vehicle and it's electrical system at risk. That alone makes owning one worth it to me.
    I personally own a pretty spartan jump start and inverter version. I separately own a compressor for inflating tires. I'm not necessarily adverse to any of the "neat" more versatile configurations that now exist. But it all depends on what you really want.
    When I bought mine? What I wanted was one potentially for jump starts for myself and others. At the time I purchased I was driving a 1990's Honda Accord....in which battery failure was a greater concern. I've never had to use it to jump start my own vehicle (knock on wood) but I have used it as temporary power during a power outage, and I have loaned it out on numerous occasions to others who's vehicles batteries needed help.
    Geo Dude likes this.
  5. Kzooman
    Kzooman Junior Member
    SW Michigan, USA
    I keep mine under the driver's seat, because remember if you're battery us dead, you won't be able to open the trunk to get it.
    Bluegrassman, The Dude and 3TE like this.
  6. Les_PL
    Les_PL Active Member
    317
    248
    Gdynia, PL
    Recently I used motorcycle battery 14Ah - fair enough. All bikers may save your wallets :)
  7. rcf@eventide.com
    173
    85
    Sedona
    The Prius is almost unique in that it doesn't use the 12V battery to provide lots of amps to a starter motor to turn over the ICE. I was able to jump start a Gen II Prius that had been idle for months just by taking the 12V 7AH gel cell from a computer UPS and connecting it to the jump posts with ordinary hookup wire.
    If you have a UPS for your computer, confirm it uses a 12V battery. (Some of the smaller ones use 6V.) Get a spare, keep it in your Prius, and swap the two from time to time to make sure the spare remains charged.
    Richard
    Steph1972, Robert Holt and 3TE like this.
  8. Les_PL
    317
    248
    Gdynia, PL
    shortly... we'll have the ideas how to bring Prius back to life with ... handheld flashlight or something :)
  9. Mendel Leisk
    38,728
  10. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
  11. ETC(SS)
    6,555
    I thought I read where somebody used a DeWalt 12v battery pack.
    As stated previously...you're not starting the car. You're booting it up.
    I have a theory that 9-"D-Cells" in a holder will boot the car, but I haven't field tested one yet.
    What I'm getting at is that you don't need a large battery pack to "jump start" a G3....IMHO.
    I like the UPS battery idea too.
    Good Luck!
    Steph1972 and F8L like this.
  12. hb06
    hb06 Member
    550
    This is good to know as I was still considering the Clore. All in all, I like the Energizer 400 Jump Start system, and the safe and easy way it has for the cables to be wrapped. It can also be left in the wall charger, shutting off when charge is not needed.
  13. 3TE
    3TE Junior Member
    40
    Miami, FL
    As Kzooman noticed the trunk lock has an electric actuator and requires active current to open? If you store the jumper in the trunk under the mat in the box... good luck trying to get to it.
    (yes, you can open the drivers door with the emergency key and open the hood to get a jump start from someone.)
    I got a small / slim one and put it just behind the rear passenger seat and bungee tied it to the side. I keep it charged with an extra long double sided cigaret lighter plug when I take long trips and test it regularly.
    Booster PAC ES5000 12V Portable Battery Booster Pack : Amazon.com : Automotive
    Or you can try this: Stanley Simple Start Battery Booster : Amazon.com : Automotive
  14. Les_PL
    317
    248
    Gdynia, PL
    Done in three minutes :)
    Geo Dude, Sergio-PL and F8L like this.
  15. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Aye. It can be done easily but if you are not fit or are very large then it may be more difficult. :)
  16. Les_PL
    317
    248
    Gdynia, PL
    I'm long with long range arms :D ,
    but shorter guy can easier crawl into the trunk.
  17. Sergio-PL
    Sergio-PL Member
    160
    46
    Poland
    I would say that accessing Prius trunk is pretty easy from inside. Especially that you can easly fold rear seats and get in.
    But isn't it better to just have a healthy AUX battery instead of carrying additional jump starter set? :D
  18. 3TE
    3TE Junior Member
    40
    Miami, FL
    I'm an old guy. My days of crawling around in back seats involved jump starts but in a different manner. ;)
    shenanigansmobile and FranklinS like this.
  19. Les_PL
    317
    248
    Gdynia, PL
  20. Les_PL
    317
    248
    Gdynia, PL
    it is - definitely - I think we are not talking about permanent solutions only Mc Gyvering in case of temporary troubles :)
