Best jumper cables for the weird connectors (read: small) in the engine bay?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SRQ, Jun 18, 2015.
  1. SRQ
    SRQ Member
    149
    55
    I had to jump my Gen II Prius at a rest stop a few months ago, and the guy that was helping me had jumper cables that BARELY fit the terminals in the engine bay. I couldn't open the hatchback because the power was completely gone, and his cables weren't long enough to run through the back passenger door and to his engine bay. We were eventually able to get it, but only barely.
    Does anyone know of a specific brand or type of cable that will easily attach to the terminals in the engine bay? His cables were the type that were "idiot proof", whereas the copper clamps had plastic covering them in such a manner that it would be extremely difficult to make contact with any other metal. I was thinking motorcycle jumper cables but they may be too thin...
    Hopefully this isn't a silly question and will help anyone in the future that searches for the same challenge.
  2. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    Basically no jumper cable can be too thin for Prius. So motorcycle jumper cables are fine. Or you can make your own. But Prius shouldn’t require jumping so if yours does you should fix it.
  3. xliderider
    xliderider Senior Member
    7,895
    3,129
    Honolulu, HI
    As mentioned above, the Prius doesn't have an amperage sucking starter motor, so even very thin jumper cables with small clamps would work.
    Buy a small pair of spring loaded utility clamps from your local big box hardware store or Walmart:
    http://pages.ebay.com/link/?nav=item.view&id=400659554036&alt=web
    Take off the vinyl cushions on the tips and handle. You can then clip those to the jump point in the fuse box, then the large heavy jumper clamp can easily go onto the utility clip. ;)
    49,735
    are those smaller than they look?
  5. valde3
    2,002
    745
    Finland
    I would prefer thinner cables. Thick cable hooked onto small clamp like that can jump off. And thinner cables cost less and fit into smaller space anyways.
    xliderider likes this.
  6. xliderider
    7,895
    3,129
    Honolulu, HI
    That's all true, but the OP didn't even own the pair used in the first post.
  7. SRQ
    SRQ Member
    149
    55
    Took a nap at the rest area and left the headlights on, there wasn't enough power to turn the car on when I woke up.
  8. valde3
    2,002
    745
    Finland
    So the fix is just to not leave the headlights on when Prius isn’t in ready :D
