Best longer life tires for 2002 Prius? Size issues?
Discussion in 'Local Prius Club Main Forum' started by grbs5000, Jun 8, 2009.
  1. grbs5000
    grbs5000 New Member
    Santa Cruz, California
    2002 Prius
    Need longer life tires for Gen I 2002 Prius. Right now have 175/65 R14. HydroEdge was recommended for long life but looks like the closest size would be 185/65 R14. would you expect that to work or would you expect rubbing or worse inside the wheel well?
  2. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    I'm not familiar with the 202 Prius tire sizes. You would get a much better response by posting this in the GenI section or even the GenII section.
    I would look into the Goodyear Fuel Max tires or Nokian tires and see if they have your sizes. I ordered my Nokians from BadBoyTires.com. The Goodyear's should be available anywhere.
    *edit*
    I checked Nokian and they do have the i3 in your size. It is a wonderful tire in my opinion. I have nothing bad to say about it and I've had them on my car (in the larger size) since last summer. :) I checked Goodyear and they don't have the Fuel Max tires in your size. :(
