Best method to drain the most coolant possible
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by ozmatt, Apr 11, 2025.
  1. ozmatt
    ozmatt Active Member
    637
    263
    Australia
    Hi all
    My V cooling system is currently full of plain water, its only slightly pink. I want to drain as much as possible to refill and not dilute the new coolant too much, how should i approach this?
    cheers :)
    #1 ozmatt, Apr 11, 2025
  2. Mendel Leisk
    42,228
    Pulling a hose off the exhaust heat recovery system should help; it’s the low point.
    there’s a link in my signature (Flushing out…) with thoughts about dealing with residual water. The basic conundrum is the Toyota Super Long Life coolant comes premixed. In a nutshell, my fix would be to look up the system’s capacity, add half that amount of (full-strength) Toyota Long Life coolant (or another, compatible full-strength coolant), then continue the fill with distilled water.
  3. BiomedO1
    BiomedO1 Senior Member
    4,475
    2,354
    Left Coast
    Was this plain tap water or distilled water?
    Plain tap water has a lot of dissolved mineral in it, especially well water. Those minerals will adhere to your coolant internals; kinda like plaque clogging up your arteries. Bottom line; if your going to put water into your radiator - you should use distilled water.
    I don't think you get too much snow sticking to the ground out there; so diluted coolant isn't going to destroy your engine. Best thing to do is use concentrated Toyota coolant to get the balance corrected again; then stick to the 50K mile OEM ascribed coolant changes there after. That should eventually rebalance your cooling system.
    Hope this helps...
  4. Mendel Leisk
    42,228
    Discussion about alternate coolants, full-strength ones:
    Zerex Asian Red vs. Toyota Long Life Red Coolant and mixing? | BobIsTheOilGuy
    Just skimming a bit of page one (of three), post #13 and #16 are especially interesting.
    Toyota Long Life Coolant, while maybe the best full-strength alternate, seems prohibitively expensive, and hard to find. At least on Amazon. This I believe is the part no: 002721LLAC01
    Still, just across the border from me, Foothills Toyota (Burlington) has it for ~$25 USD per gallon:
    Genuine Toyota Long Life Coolant
    And..., from my local Canadian dealership part department: in stock, roughly $28 CDN, per US gallon (aka 3.785 liters :rolleyes:)
    Coolant spec, from third gen Owner's Manual:
    "Toyota Super Long Life Coolant" or similar high quality ethylene glycol based non-silicate, non-amine, non-nitrite and non-borate coolant with long-life hybrid organic acid technology.
    Engine coolant system total capacity, from Repair Manual (excerpt attached):
    ^ According, when refilling, I would start with 4 US quarts, then finish with distilled water.
    FYI: Toyota USA sells the pre-mixed Super Long Life at 50/50, while Toyota Canada makes it 55/45 (coolant/water). Doing the math with 7.7 US quart capacity and "Canadian" mix, that'd be 7.7x.55=4.235. Doing the math with "US" mix: 7.7x.5=3.85. So 4 US quarts (the size of container it comes in) is a good compromise quantity.
    #4 Mendel Leisk, Apr 12, 2025
    BiomedO1 likes this.
  5. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    On Australian Prius V this system may be absent. In countries where there is no snow, it is unnecessary to heat the coolant.
  6. rjparker
    rjparker Tu Humilde Sirviente
    10,953
    6,872
    Texas Hill Country
    Assuming it has water from the tap, you need it out to the best of your ability. Drain and measure the amount removed.
    I would buy five or six gallons of distilled water and do four drain and fills with full circulation (which means warmed up so the thermostat opens) in between.
    Since each drain cycle gets 2/3 of it out each time the original tap water becomes extremely diluted for $1 a gallon distilled water times five. Add a gallon of Toyota concentrated coolant and top it off with distilled water if needed. Change coolant every 40-50 k miles from then on. It's muscle memory at that point and easy to do.
    Your head gasket will appreciate it.
    #6 rjparker, Apr 12, 2025
  7. Mendel Leisk
    42,228
    I think the "concentrated" coolant (not diluted with water), at least Toyota Long Life coolant, has half the service interval. Accordingly, I'd replace that coolant after 2.5 years or 25K miles, just the first time, and then revert to 5 years or 50K miles, assuming you carry on with Super Long Life coolant.
  8. ozmatt
    637
    263
    Australia
    Thanks guys,
    Mendel we don't have that silly heat exchanger system thingo here, although I'm down south and it does get cold and sometimes snow
    "Apparently" Australian tap water (particularly my town) is relatively mineral free and pH balanced and is generally considered safe to use in automotive cooling systems, not 100% sure if I have been given the wrong advice or not but that's the general consensus around these parts anyway, I will do some extra research on that before I proceed
    I like the idea of using red concentrate at 50/50 with water and its what I would normally do in this situation but I have already acquired a full 5L bottle of SLL pink coolant so was hoping to use it
    According to the manual the cooling system is 6.5L in Australia without the heat exchanger.. I may have to use this bottle of SLL pink in another car and re buy some red concentrate
    #8 ozmatt, Apr 12, 2025
  9. BiomedO1
    4,475
    2,354
    Left Coast
    I'm 90% sure, whomever told you this is incorrect. You can get away with using tap water on old cooling systems, but on these modern cars with narrow passages and coolant control valves - they can get clogged up; rusty. If you know any steamfitter or someone who's ever managed a boiler system - they should be able to give you a good education on what happens to water and mineral deposits. Distilled water is mineral free and I don't think they pumping that through your taps.
    There's a thread somewhere where a gen4 Prius coolant valve got jammed, rusted partially open. The car had over 200K miles and owner never did a coolant change. I'll adjust this thread if I can dig it up.
    ozmatt likes this.
  10. ozmatt
    637
    263
    Australia
    Hi Biomed01
    Maybe i am not 100 on the subject.. its region specific i guess, I don't claim to know much on the subject but from the research i have done
    For Adelaide, QLD or NT you definitely would not use tap water, here in Tasmania or even Melbourne it's considered okay to mix tap water with a quality modern coolant. Our city supplied tap water here in Tasmania is considered very soft and know to be some of the purest water in the southern hemisphere, I don't claim to understand the science of water quality or what the info below really means but apparently its good !!
    TDS 40ppm
    GH 11ppm
    KH 13ppm
    I am not saying its correct but virtually all of the mechanical workshops and cooling system specialists alike in this state all just use tap water and have done since I can remember, buying water for an automotive cooling system is virtually unheard of here..
  11. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Distilled water is used to service acid batteries and it seems that it will not be difficult to buy.
    The price will be less than a dollar per bottle.
    You can buy a ready-made composition from a dealer and not dilute the concentrate yourself.
  12. ozmatt
    637
    263
    Australia
    Hey Max, its actually tricky to get distilled water in my town and its $2.50-3 /L when you can find it, demineralized water is cheap and eazy but that's not what we need for this application apparently.
    I have a 5L bottle of genuine pink premixed SLL but cant use it for this one unless i want it to be diluted because the cooling system is currently filled with plain water
    Just got a bottle of the local parts store in-house brand concentrate pink toyota/lexus specific POAT coolant
  13. Mendel Leisk
    42,228
    Then radiator drain is likely the lowest point, will drain the most.
    Pouring in a suitable, undiluted coolant (not a 50/50 pre-mix), an amount calculated to be half the system capacity (or slightly more, say 55%), and then completing the fill with distilled water, is the only effective way to get a water-flushed system back “in balance”, at least that’s all I can think of. Several preliminary flushes with distilled water maybe be warranted, depending on your water supply.
    I’d use the pre-mixed Toyota Super Long Life coolant (you have on hand) at the next coolant change, which should be in 2~3 years (shorter replacement interval recommended by Toyota).
    #13 Mendel Leisk, Apr 13, 2025
  14. BiomedO1
    4,475
    2,354
    Left Coast
    The 40ppm is total dissolved solids = minerals. FWIW: our water treatment plant average is 44ppm and ranges from 26ppm-61ppm. Deminerialized or deionized water would be better for your car's cooling system
    Here's the thread I was talking about. Car is Juddering / Jerking during acceleration… | PriusChat
    Thread #6 img_7524.jpg; That's OEM Toyota coolant without the additional tap water mineral. Though the coolant may have turned slightly acidic due to ignoring the change interval. He had over 300K miles on it - not kilometers. As you can plainly see, you can get away with things that isn't completely "kosher", but the small cumulative effects will eventually catch up with you..
    YMMV
    Here in the states we mostly refer to it as distilled water vs mineral water (the stuff people drink because it's suppose to be better for them). My old facility had a boiler plant to produce heat, energy generation and supported scientific labs, where we produced our own deionized water; so it wouldn't throw off our test results. This means that everyone got a crash course on how and why we do things.......
    #14 BiomedO1, Apr 13, 2025
  15. ozmatt
    637
    263
    Australia
    Thanks Mendel I will do exactly that, have acquired a bottle of Toyota / Lexus POAT concentrate from the parts store
    Cheers Biomed, I can get demineralized water quite easily is that a fair substitute in your opinion? seems that's what a lot of people are using and is what the car parts stores are selling
