best mileage with cruise control or no?
Discussion in 'Gen 2 Prius Fuel Economy' started by Bob Allen, Apr 1, 2005.
  1. Bob Allen
    Bob Allen Captainbaba
    1,273
    Seattle, WA
    Anyone done a comparison to determine if using the cruise control as often as possible improves mileage over using the "lightfoot" technique on the accelerator to minimize the ICE operation? Cruise control is certainly easier on the foot.
    Bob
  2. priusham
    priusham New Member
    525
    Michigan - land of everlasting snowflake icon!
    I agree with your last sentence 100%.
    My own experience over the past two fill-ups and switching from CC to lightfoot proves that a skilled Prius driver will beat CC by a large margin.
  3. Dave
    Dave New Member
    340
    Santa Cruz, CA
    I use cruise control when I'm lazy and when traffic warrants. I'm often lazy, but traffic is thick where I live.
    I can definitely get better mileage on my own.
  4. mikepaul
    mikepaul Senior Member
    1,763
    Columbia, SC
    Some of us (OK, me) can't pull off the 'feathering' effectively enough to gain extra MPGs. I stick with CC when I can, and I'll live with the MPGs I get. 48 today, so I'm not crying...
  5. Charles Suitt
    Charles Suitt Senior Member
    1,637
    16
    Dallas TX
    :) I use CruiseControl whenever practical. I have found that the Prius computers do a noticeable better job on fuel economy than my foot can. My CruiseControl rarely varies ±1 MPH from the set speed and is much more sensitive to hills/valleys and rough/smooth/wet/dry pavement conditions.
  6. mtc1234
    mtc1234 New Member
    39
    Laurel, MD
    If I didn't use Cruise, I'm sure I'd get much worse mileage to and from work. Cruise keeps me from accelerating past people and jockying for position. People talk about the Prius helping to control their type A driving personality. Well, the Prius + CC is what does it for me. I put in cruise about 64mph on my way to work. Whereas that's 9mph above the speed limit, it's about 6mph below what almost everyone else drives. Using the 1mph up and down adjustments with the CC, I anticipate and adjust for changing patterns in the traffic. Usually, I only have to drop it out of cruise one or two times during the commute (I am conscientous, and try not to make vehicles slow down when I enter the left hand lane).
    So, cruise helps me, but it's not a technical thing.
  7. Ray Moore
    Ray Moore Active Member
    857
    52
    Texas Hill Country
    By allowing your speed to fall below the mark going up the hill and rise above the mark on downhills, you can significantly improve mileage compared to cruise control.
  8. RBW111
    RBW111 New Member
    139
    El Dorado, AR
    With CC on you can still lightly press on the gas pedel when going down a hill and you will coast. When the car slows to 1mph less than you have it set to, it takes over. I don't know if this improves mpg, but it should.
  9. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    It all depends upon the skill of the driver in manipulating the vehicle and what the objective is. If the objective is to maintain X-mph speed then there probably isn't a lot of difference on flat road.
    But I definately feel that driver control allowing some speed loss up-hill and optimizing momentum gain with 'gliding' downhill then hitting Cruise on the flats b/w can, over time and distance clearly offer superior gas mileage when done correctly.
  10. Ray Moore
    857
    52
    Texas Hill Country
    I've found that even on the flats, I can do better than cc. Taken to the extrreme means coasting in neutral and then replacing the lost speed with gentle acceleration, a practice best suited to empty country roads.
  11. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    i use CC 95% of the time. although in my area where there is no flat areas, moderating speeds to take advantage of gravity is advised. CC has a tendency to "overcompensate" at times for very slight uphill slopes if one doesnt bump the speed down a bit.
    but for me, in all but the most extreme of hills, using the incremental adjusting technique works for me. in town, using CC forces me to anticipate traffic and not start to space out on other things. i often wondered if i would wear the button out because it usually requires a lot of driver intervention to use CC effectively in city traffic.
    i dont use neutral at all but do a lot of coasting. in nearly all situations, i am on multi-lane streets so i will coast up to a light from 5 blocks back if i know the lights will force a stop and h*** with anyone behind me. and yes i have had SUV's go roaring around me just to have to slam on their brakes to stop behind a line a 20 vehicles sitting at the light. but... its their money...
  12. Ray Moore
    857
    52
    Texas Hill Country
    Why is it almost always large trucks and SUVs that do that? Oh yeah, That's most of the vehicles on the road here in Texas.
