Best Mode for driving Prius Prime up Steep Hill for vehicle longevity not best mpg?
Discussion in 'Prime Main Forum (2017-2022)' started by ride43, Oct 29, 2017.
  1. ride43
    ride43 New Member
    25
    Walnut Creek, CA
    I drove up a steep hill around 15% grade for just under a mile. I believe I was in eco mode, with no EV stored. I went about 15mph and it had a burning smell like I have experienced with other cars when I got to the top.
    A few days later I did the same thing, but I went up in EV mode again around 15mph and there was no smell. I know this is due to the ICE not running.
    So the question is this: Is it harder on the car to go up using the ICE or the EV? Is there an optimal speed to go up? I know for traditional ICE cars the slower the better. But under EV does that matter, other than battery drain? On the way back down i switched into B mode and regenerated a lot of what I lost on the way up.
  2. Tideland Prius
    16,445
    The burning smell could be from the inverter. I'll have a similar electrical burning smell if I accelerate hard for a good 10 seconds. (Did that once with 5 ppl in the car on an onramp that was uphill and merging onto I-5 I think... one of the WA highways lol)
    Perhaps go with a battery that has more charge (not necessarily full). That way, even in hybrid mode, the car can rely more on the battery.
  3. bresna
    bresna Active Member
    193
    144
    Southern Maine
    I thought that B mode disconnected the charging function? That's what I was told for my first two Priuses (2004 & 2012).
  4. Trollbait
    12,351
    How long have you had your Prime, the smell could be cosmoline, a lubricant used during manufacture, burning off.
    Charging still happens while in B. The net charge gained from regen will be lower because the car is spinning up the ICE to throw away excess energy.
  5. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    Only N disconnects charging of the HV battery. (the 12 volt battery charges anytime you are in READY)
    B 'wastes' more energy than D, but does not disconnect the electric motors entirely.
    pilotgrrl likes this.
  6. ride43
    ride43 New Member
    25
    Walnut Creek, CA
    I appreciate all the replies. It is a new car just a week old. I am not overly concerned about if I should use D or B going down. I imagine B is better as it slows the car more similar to being in L for low grade, but if D works to slow down just as well, then I can do that too.
    My main question is going up, what is harder on the car electric, or engine? I just want the car to last as long as possible. So I don't mind getting worse mpg depending on which mode is easier on the car to go up.
  7. Trollbait
    12,351
    Don't worry about it. Either the electric motor or ICE can handle an incline without a problem. If they couldn't, Toyota wouldn't have made it as a car company. The Prius is one of their most dependable models. Unless your goal is to have the car for a million miles, there is no need to stress over how to baby the car.
  8. Mendel Leisk
    40,586
    With a regular Prius the main purpose for B is on steep, protracted downgrades, where there's a risk of the battery being fully charged, with a long downhill stretch STILL in to come, and braking now being handled solely by the friction brakes, possibly overheating them.
    That said, I think B behaves differently in the Plug-In Prius and Prime??
    Andyprius1 likes this.
  9. ride43
    ride43 New Member
    25
    Walnut Creek, CA
    Fair enough. I guess the answer I was hoping to hear is that if I am just using the electric motor in EV that I can go up as fast as I like and really push it up the hill with no ill affect. Years ago I had a friend floor his minivan in low gear up the hill and his engine blew so I have always been real careful going up the hill. But being an electric motor I wondered if it could handle a little more stress.
  10. Tideland Prius
    16,445
    With an electronic CVT, the car is never overrevved; the computers make sure of that.
    Even if you floor it, you're not at redline since the max torque of the engine is somewhere around 3,600rpm for the Prime/Gen 4 Prius. (Redline is 5,200rpm).
  11. GT4Prius
    GT4Prius Active Member
    530
    412
    Cumbria, UK
    Excel
    You may like to read the manual concerning traction battery life and capacity reduction. My take on what it says, reading between lines is that using EV in a way that puts very heavy demands on the traction battery, may create more wear on the battery life and capacity, than normal driving.
    My view is also that in some circumstances the ICE may be more efficient and economical on hills, if this allows saving EV power to be used in other parts of the journey where power demand is less.
    But others may have more detailed knowledge on this matter than I.
  12. Trollbait
    12,351
    That sounds like more of a problem with the driver than the car.
    I bet the burning smell you got was normal for a new engine, and you won't experience it again on that hill. The hybrid system has a plenty of self protection built into the software; it watches rpms and temperatures of the components.
    If you need to ease your mind, use EV Auto on steep hills. The car will switch to ICE operation sooner than in EV mode if the systems feels it is warranted.
  13. ride43
    ride43 New Member
    25
    Walnut Creek, CA
    Thank you guys very much for the information. That is great to know about the automatic redline limited. Also the idea of using the engine uphill to save stress on the battery makes sense. So it sounds like EV Auto may be the mode to use when unsure of what to do.
  14. Tideland Prius
    16,445
    If you watch this video starting at 3:00, he's in EV Auto mode and when he goes past 45-47mph, the engine kicks in.
  15. E-GINO
    E-GINO Active Member
    194
    206
    Rome, Italy
    While I am writing this post my Prius is recharging for the third time only, so my experience with this car is very little. But since in my typical Sunday tour I have a couple of hills to climb (one on the way, another on the return) and, in terms of battery range, an uphill kilometer worth at least two flat - in my case let's say two and half - I do the hills in HV mode.
    Now, since I do not believe that any ICE likes to be stressed while it is still warming up, I commute in HV mode just a couple of minutes before tackling the ascent. Here, I think this simple precaution can preserve the engine life long enough.
  16. fneil
    fneil Member
    71
    52
    Carrboro, NC
    I got a 'burning smell' once when I first got the car, during hard driving (loaded, uphill, main road requiring some speed). Don't recall for sure what mode, but probably HV. It hasn't happened again, so I figure it was some drivetrain component's coating getting heated up for the first time.
    Trollbait likes this.
  17. Those were some nice smells to go with "new car" smell. When I test drove mine the odometer had 8 miles on it :LOL:
  18. Mark57
    2,945
    2,738
    OK
    Most likely the exhaust/cat converter burning off the new shine.
  19. So, on my usual commute, one of the roads has been closed except to local traffic. So, I used the nearest road over, which is a steady, steep uphill. I decided to do an experiment in controlled conditions, like similar morning temps, heat turned off, from 0 mph at the traffic light to just cresting the hill at 40 mph and can get off gas, etc., to see how uphill acceleration affects range driving on electric.
    Nov. 8: Maximum acceleration, using 180 A, average increase of around 6 mph per second. Available battery capacity dropped 5%.
    Nov. 8: Reduced acceleration, using 60 A, average increase started 4 mph per second and dropped to 2 mph per second (don't worry, no vehicles followed behind me). Available battery capacity still dropped 5% even with reduced acceleration.
    So, essentially not significantly better to go slow than to "just use the car."
  20. PT Guy
    PT Guy Senior Member
    1,085
    711
    Washington, the state
    Never had a burning smell from our new Prime. It could be as stated from the corrosion preventative cooking off. Cosmoline a term used generically for a waxy corrosion inhibitor.
    I use EV Auto for steep hills. The engine will do fine. It's controls are smart. I like Gino's suggestion to run the engine on a easy section to warm it before it gets to the hill. I start off in EV Auto for a trip where I know I'll fully deplete the battery. I get lower total fuel consumption for the trip than if I started off in EV and let the engine automatically run after the battery was flat. The system knows when to run the engine up hill and save battery power.
