Best oil? 0w20 or 5w30
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by qdllc, Dec 2, 2025 at 9:00 AM.
Tags:
  1. qdllc
    qdllc Senior Member
    1,376
    400
    A good question. Supposedly the 0w20 is to meet higher MPG demands in the USA, but that same motor would be fine with 5w30. Slightly less MPG but significantly more protection for the motor.
    Thoughts?
  2. Prodigyplace
    12,547
    11,771
    Central Virginia
    i am sure Toyota could have reached the mpg demands without using a special oil. The engine tolerances were designed for 0w-20 oil so you should use that. Some of the latest engines are now designed for 0w-8 oil. I used 0w-20 oil for several years in my 2017 Prius with no issues.
    BiomedO1 likes this.
  3. priumium
    priumium Member
    134
    29
    Sweden
    The info I have heard from Toyota is that 0w20 is filled at factory for the initial virgin period and then replaced with 5w30 - atleast in Europe.
  4. Prodigyplace
    12,547
    11,771
    Central Virginia
    Toyota did that fir some models when the factory oil was not readily available in some countries. For instance, on my 2017 Prius,. rumor as it had 0w-16 but the US manual said 0w-20 because 0w-16 was not widely available.
    You should go with the recommendation from the owners manual for your country. In most cases, it is available online.
  5. BiomedO1
    BiomedO1 Senior Member
    3,555
    1,840
    SacTown, Ca
    Engines receives its most wear during startup; before engine oil makes it to where it's needed. Newer engines has tighter tolerances and smaller oil passages; mainly due to experience and better tooling. The oil itself is full synthetic and more uniform than old school dino oil and also resist stress & thermo breakdown better. The Prius engine starts and stops more often than a regular car engine and once the engine is running; it's mechanical parts are floating on a cushion of motor oil.
    The majority of Toyota motors reach 200K trouble-free miles, if you exclude the gen3s; so I think the Toyota engineers know what they're doing. I wouldn't second guess them with that track record.
  6. priumium
    priumium Member
    134
    29
    Sweden
    I doubt this was made because the oils where not readily available. A new motor needs special care. Sounds like a rumor indeed.
    Anyhow, 5w30 is recommended on eu models. Always check the oil fill cap for the recommended type. And use a quality filter, OE is cheap.
    #6 priumium, Dec 2, 2025 at 11:25 AM
  7. Mendel Leisk
    41,390
    I've toyed with switching from 0W20 to 5W30, for one oil change at least, see how it goes. Or hey, 5W20?
    It does stretch credulity, the steady march towards thinner oil, and the disparity in policy: different countries, different oil weight recommendations, with the same engine.
    priumium likes this.
  8. BiomedO1
    3,555
    1,840
    SacTown, Ca
    FWIW; I'd be hesitant to go with a heavier oil in a cooler climate, anywhere that snow sticks to the ground. Anyone who has lived in snow country remembers to go to a thinner oil in the fall-winter months. If your young enough to only see multi-grade oils, you won't know what I'm talking about.
  9. priumium
    priumium Member
    134
    29
    Sweden
    This seems very absurd and unlikely to be proven scientifically.
    How are US winters much worse than Scandinavian/Swedish winters? Apart from Alaska perhaps… but Sweden reaches beyond Alaska longitude wise…
    Then why would Toyota ”recommend” 0w20 in the US and 5w30 here? Just read between the lines is my own analysis.
    However, there are many sources stating this counterintuitive ”fact” for worried users. It’s likely mainly a bunch of crap based on some commercial interest… Or?
    Change the oil often is much more important. As often as you swap tires is my own concept… Oh that’s only a thing for us up here. Every 5k US miles ok?
    I have very good experience with the Castrol Magnatec 5w30. I bought a really badly maintained Prius 2005 last year. It took me four full engine oil replacements to clear that engine of contamination over 12 months. Runs like a dream now and has clear oil after 2kkm. (3k miles)
    I do not think oil flush additives are better than full replacements. And at 30 eu per 4 liters it seems uncalled for.
    #9 priumium, Dec 2, 2025 at 1:36 PM
