Best oil filter for 2006 Gen 2 Prius and where to buy
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by JBuckPrius, Nov 19, 2018.
  1. JBuckPrius
    JBuckPrius Junior Member
    64
    Knoxville, TN
    Hi all. I'm going to be doing my own oil changes. What filter is best to buy? Toyota filter or aftermarket? Where do you buy yours and what are they going for? It the Toyota filter actually better? Any links online? Thanks.
  2. JC91006
    16,674
    8,519
    You can buy Toyota oem filters for the same price as aftermarket on online sites
    m.wynn, JBuckPrius and Raytheeagle like this.
  3. 05PreeUs
    05PreeUs Senior Member
    1,097
    564
    MSP
    "Best" is subjective.
    While WIX, Purolator, FRAM, BOSCH, ACDelco and Mahle are all constructors of quality branded and sub-branded filters, you really do not know what you are getting unless you purchase an OEM filter built to factory specifications by one of the above specialty firms. No automotive OEM that I am aware of actually makes filters, but they do set STRICT specifications for them, which are often disregarded to increase profits in the "aftermarket".
    My suggestion is to buy OEM if you can and if not, at least a world-wide manufacturer of filters as noted above.
    m.wynn, Mendel Leisk and JBuckPrius like this.
  4. jzchen
    jzchen Newbie!
    3,316
    1,020
    Arcadia, CA
    I buy Fram Ultra filters at Walmart. I did not check if local Walmarts have the specific one for your Prius model, but it is Fram XG4967, (unless I made a typo). 99% filtration efficiency down to 20 microns with 20k mile rating. Prior to that I was using Mobil 1 Extended Performance with “A” appended to the part #. 99% efficiency down to 30 microns with 20k mile rating. Pick one up, open the box, and you can see/feel the substantial difference.
    My $0.02.
    Skibob and JBuckPrius like this.
  5. bisco
    51,155
    oem online
    Georgina Rudkus and m.wynn like this.
  6. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    $3.95.
    2006 Toyota Prius Parts - Camelback Toyota Parts - Genuine OEM Parts - Free Shipping
    Free ground shipping of $150+ in purchase. Easy to hit $150 spend if you group lots of OF, and other maintenance parts (water pump, belt, idler pulley, inverter pump, crush washers, brake pads, brake shoes, etc). If friends drive Toyotas, combine their maintenance items with yours, so you don’t have to spend as much.
    Your local dealer’s website might list parts specials; oil filters might be at a reasonable price. Ask if they will match online Toyota dealer prices, if not reasonable.
    Crush washers cheaper from Amazon and fleaBay (eBay), bythe big bagfull vs individually.
  7. johnjohnchu
    johnjohnchu Active Member
    211
    104
    I always buy 10x Toyota OEM oil filters from eBay to get the best price. Of course this also includes free washers and free shipping.
    #7 johnjohnchu, Nov 20, 2018
    TGrracie and m.wynn like this.
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    Oem $4 at dealer or Amazon or eBay.
    Part number 90915-YZZF2
    Years ago at my dealer they used to come with the oil pan bolt washer. Not included anymore. If car new to you pick up one of those washers too. I replace my washer every few changes. Don’t have that part number.
    ydpplqbd likes this.
  9. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
  10. MichaelKnight
    MichaelKnight Junior Member
    39
    22
    Westcoast
    Oem oil filter in bulk not to forget drain plug gasket.....Sometime when a promo comes up I go with mobil 1 filter...hope this helps
  11. Phildo
    Phildo Active Member
    138
    108
    Perth, Western Australia
    i-Tech
    I use the PurolatorONE PL14477 on both Prius and Camry Hybrid.
  12. Mendel Leisk
    40,586
    I've been buying everything in person, at dealership parts counters (various: Honda, Toyota, now Mazda). Buy stuff just-in-time.
    Still, over the last decade I've noticed a phenomena: pretty much EVERY time I arrive at dealership, it's nigh impossible to find a parking spot. :confused:
    Thats for OEM products, oil filters. If it's something like spark plugs for example, I use a local auto parts specialty place.
  13. Patrick Wong
    18,200
    6,493
    Amazon Prime or order from a Toyota dealer online...
    Raytheeagle and Mendel Leisk like this.
  14. Mendel Leisk
    40,586
    I'm usually filling up my bulk oil container too, killing two birds. And I can drool over the new cars a bit. Plus we usually pick a sunny day, go from there to rocky point park with the shiba, ice cream for all. :)
  15. Skibob
    Skibob Senior Member
    2,912
    1,502
    Northern California
    I use Fram myself but I recall someone saying you can get a longer filter at the dealer. That would sure help in getting them off.
  16. hesty24
    hesty24 Junior Member
    San Antonio, Texas
    I guess I have been getting lucky with my crush washer. Original 2007 washer, every 5k oil change (DIY), not one drip from it ever!
  17. ydpplqbd
    ydpplqbd Active Member
    551
    253
    I use Fram PH4967 which I purchase at Walmart. I find it easier to not stock up and just buy what I need when needed.
    I change oil every 5000 miles. If I was using a longer oil change interval then I would likely use a more spendy oil filter.
    ETA: Currently, Fram PH4967 filters are $3.88 at Walmart plus sales tax.
    #17 ydpplqbd, Feb 2, 2022
  18. JC91006
    16,674
    8,519
    Any brand name oil filter would be good enough for a Prius engine. I pay $3 for Bosch workshop filters
  19. nemebean
    nemebean Junior Member
    42
    28
    Apparently the contemporary Camry filter is compatible and longer. I've never bothered since the ones I buy are rated for longer intervals than I'll ever go anyway, but it's something to try if you want.
  20. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,353
    2,347
    Taylors, SC
    Unfortunately, after many years my dad and friends having used them, I have found that Fram filers are really poor quality.
    I now only buy genuine Toyota off of Amazon.
