Best Prius to buy? No kids No Wife
Discussion in 'Gen 3 Prius Main Forum' started by mpglol, Apr 28, 2016.
Tags:
  1. mpglol
    mpglol New Member
    Dallas
    Hey there college student who just finished graduating looking for prius that will get me the best MPG but won't break the bank either. I had a 95 Cobra that I recently just sold and now just have my baby 94 mkiv supra, but I wouldn't dare daily her. I just use her for car shows and car meets. Want Prius get me around since I heard nothing but great things and I am all about saving gas. Most I would pull myself to spend is 8-10k but have 5k in cash.
    Attached pics of old car and my baby
  2. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
  3. mpglol
    mpglol New Member
    Dallas
    I rather buy my dream muscle car for 12-15k thats buckets of money locally I have some stuff but mostly with high miles thats why I haven't pulled the trigger but just saw an 06 80k miles for 6500
    #3 mpglol, Apr 28, 2016
    mmmodem likes this.
  4. dorunron
    3,318
    1,105
    Houston, TX
    Well, since you are a college graduate and I am just a old man who is retired with a GED, I am going to say Good luck to you.
    Sorry if that sounds rude, but it is what it is. FWIW, that 06 Prius has NO warranty whatsoever. A traction battery failure is a easy grand or two and that is refurbished, not a NEW one.. A transaxle failure, another easy grand or two, but who am I to say what is right for you. If it's worth 6500 to you, then buy it.
    But I still stand by what I said originally 12 to 15K for a DECENT RELIABLE machine.
    apt5020 and Coast Cruiser like this.
  5. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Yup, I'd take the $5k and buy the newest and lowest mileage Prius you can get. That will probably be a 05 or 06 model. Don't get a car loan. Save the monthly payments you would be making and in 5 years, you may have enough for a brand new car.
  6. fotomoto
    fotomoto Senior Member
    5,632
    3,805
    So. Texas
    As someone who's been looking at the used market for several months, you won't find a good gen3 in the 8-10k range that doesn't have a lot of miles or salvage title. Although rare, low miles gen2 can be found in that price range with a new battery figured in. Rule of thumb I have for HV battery is 10 years working life.
  7. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    Get whatever old one you can find/afford, and just drive it until she blows! :LOL:
    As a new member to this forum, I was pretty shocked to see several hundreds of posts (maybe thousands?) related to mechanical & electrical problems. I was fooled into thinking the Prius was a "technical marvel" that only required a minimum of preventative maintenance. I saw all these Taxi Cab companies changing over to the Prius... and that convinced me to buy one. They gotta be great cars if Cabs are using them!
    I'm sure there are lots of success stories, too. But man, I never expected to see so many problems.
  8. FroggyTaco
    FroggyTaco Member
    211
    59
    Paso Robles, Ca
    I would argue there is a lot of discussion repeatedly over the same problems & also a lot of concerns that are not actual problems aside from the individual Prius owner not liking that aspect of the cars operation or design. In a lot of other car forums when a new person posts asking for something that has already been heavily discussed they are either referenced to that thread(s) or shamed for not using the search engine.
    PriusChat is somewhat unique in that the same "problem" gets rediscussed to varying degrees over & over. I assume that's a byproduct of the average Priuschat member personality.
    I'm going to disagree with your perception. These cars are not invincible, however for the level of tech & relative infancy of the technology my assessment is they are way above average reliability.
    The actual number of significant failures that cost several thousand USD equivalent are fairly low excluding traction batteries. And if you read enough about traction batteries there's pack's that fail in 40K & some that fail after 400K+ miles. And a whole lot in between. For example if you don't keep the cooling fan clean & free flowing you can kill a pack. A multi thousand dollar repair due to very simple preventative maintenance.
    For me the big takeaway is the ongoing preventative maintenance is actually very low & the car doesn't need to be babied nor does it have a fussy nature that demands certain parts to be replaced on an ongoing basis due to a engineering deficiency.
    I would however avoid the first year of any of the Prius generation but that's a valid position for any car made by any manufacturer. In fact the last year of production is typically the most reliable because the factory already rectified all significant known issues. That is especially applicable to the Prius with it's longer than average vehicle lifecycle.
  9. wjtracy
    wjtracy Senior Member
    11,363
    3,607
    Northern VA (NoVA)
    If you could be lucky to find a $5000 Gen2 that already had a new replacement Toyota hybrid battery, that would be cool, but non-Toyota or rebuild batteries are not as good for you unless you are inclined to DIY the fixes. Lots of guidance here on DIY. Lot's of orig Prius batteries last a long time, but somehow it seems like the used Prii bought on the open market are more problematic than those of us who just maintain well and hold it ourselves for 200,000+ miles.
    The other thing is TX does have some good battery fixers on-line here.
    #9 wjtracy, Apr 28, 2016
  10. ETC(SS)
    7,057
    The best used Prius for $5k would be a used Corolla.
    10K starts to break towards Priuses, but only because you'd have cheaper TCO to break away from the higher buy in.
    If you know how to swing wrenches, you can certainly make a G3 Prius go past 200K, but you're gong to be significantly over 100K for a decent G3, and a low mileage G2 starts to get into age related risk rather than wear related unreliability.
    Of course all of this depends on what's to come in the job department, how much you drive, and how much of your future you hocked (if any) to get through school, as well as other debt loading.
    Depending on the answers, you might need to spend a little more on daily transport - and that daily driver need not be a Prius if you only drive 3 miles to work every day.
    Good Luck.
  11. mpglol
    mpglol New Member
    Dallas
    okay everyone buying 06 toyota prius with 65k miles for 5900 from my research over countless days months think its the best deal out there I've seen the 06 model go into 250k range so I'm pretty confident with my mechanically inclined self i can make it last
    let me know good deal bad deal?
    am I going regret it?
    Buying it tomorrow april 29
  12. wjtracy
    11,363
    3,607
    Northern VA (NoVA)
    I'd be curious to know hybrid battery orig or what status? 65k suggests less wear on tear on vehicle, so it should be nice, but somehow it seems lower miles is not a guarantee of longer hybrid battery life especially in TX. So just keep in mind that HV batt is probably aging by years in hot climate rather than miles. Sounds like you can handle it!?
  13. mpglol
    mpglol New Member
    Dallas
    Sounds like I need to be a quick learner haha
    Nooo if I can't ill just find someone here local in Dallas that can
    prius will be outside garage belongs to the supra
    haha thats the plan drive until she blows then find another one or a little honda
    #13 mpglol, Apr 28, 2016
  14. fotomoto
    5,632
    3,805
    So. Texas
    I got an 06 last month with 45k miles (little ol' lady owned) for $6200 so I think you did well.(y) In case you don't know, you can enter the VIN here: Toyota Owners Official Web Site and find out some of its prior history.
  15. wjtracy
    11,363
    3,607
    Northern VA (NoVA)
    ...I certainly don't think we should be sending 2006 Prius with <100,000 mile to the elephant grave yard. Eco-mindedness means using it up to 250,000+ miles, not just buying less gaso. If you're buying less gas but retiring the vehcile, what good does that do for the environment? All that equipment has a cost to the environment too.
    zmre2b, CR94 and Lightning Racer like this.
  16. FroggyTaco
    FroggyTaco Member
    211
    59
    Paso Robles, Ca
    I would just try to make sure it hasn't had it's odometer "rolled back" & there's an extra 100K on it.
  17. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,802
    1,170
    Auburdale FL
    My 2009 Touring Four with leather is in perfect condition and one owner. Dealer trade if I don't sell it. New GY Assurance Fuel max tires BTW and tranny fluid changed once. 97K new rear latch assembly, window film, accessory belt, water pump.
    Probably the best car they made as the Touring was a limited production..
    Started a sales thread sorry.
    #17 ETP, Apr 29, 2016
  18. Steve Lee
    Steve Lee Member
    135
    88
    Houston
    I purchased brand 2006 (Gen 2 Model III), I liked the car until it crashed by a person texting while driving. What I did not like was the small instability while driving 65+ MPH, and when there is wind instability more noticeable compared to Gen 3 or Prius v.
    Since you have budget 8K-10K USD and you wanting to purchase 06 for 5900, you can use some of the budget for repairs and upgrade suspension/chassis.
    Is kind of rare to find 06 with 65K miles, that's an average of 6500 miles a year...Since you live in Dallas Texas, and there has been several flooding past years, I suggest you do you due diligence.
    As I was told "You are in Texas, you need a pick up truck".
    ETP likes this.
  19. ETP
    2,802
    1,170
    Auburdale FL
    Old PU truck would be nice. 1948 Chevy.
  20. Jimi1976
    Jimi1976 Active Member
    242
    124
    Denver, CO
    The Prius I currently drive (2010 III),can be had for about 10k.
    It's still a great car.
    6 years old is a baby for Toyota.
    Don't let anybody else tell you otherwise!
