Best range modes street vs highway
Discussion in 'Prime Fuel Economy & EV Range' started by 4rpr15, Nov 28, 2017.
  1. 4rpr15
    4rpr15 Senior Member
    1,056
    375
    WI
    I have 19 miles to work and back and I use EV Mode. When I go on the highway should I switch to HV mode even if I still have EV miles left?
    49,520
    only if you don't want to use them.
    4rpr15 likes this.
  3. 4rpr15
    1,056
    375
    WI
    I'm reading all over that members use HV mode on the highway to preserve EV miles on regular street driving. What difference does it make. That's the part I'm trying to understand.
    49,520
    the only difference is that the faster you go, the more energy you use. so you will get less ev miles on the highway than side streets.
    but you are warming up the engine and burning gas alternatively, so, it's just a game really. choose your poison.:cool:
    4rpr15 likes this.
  5. 4rpr15
    1,056
    375
    WI
    I'm in WI so is it true that I should leave it plugged in when parked at all times? I normally just plug it in overnight and unplug it when I wake up. It gets VERY cold here. I'll rarely use the defogger, just when needed for emergencies.
    priuscatprimeguy likes this.
  6. audiodave
    audiodave Active Member
    787
    268
    US
    I would think the charging system would shut off accordingly as needed. Should be fine to leave plugged in until you use the car.
  7. 4rpr15
    1,056
    375
    WI
    Wastes a bit more power, but not much I imagine. I read that members leave it plugged in so that it keeps warm. What's behind that?
  8. Ferrarilover
    Ferrarilover Active Member
    185
    168
    Manchester, UK
    The way I see it is that it takes a certain amount of energy to move the car at x speed. Electric is cheaper than gas so i just want to use that first. At street speeds rather than highway it can still slip into electric mode anyway quite often as it is acting as a normal Prius once the battery has dropped to the lower level.
    iPhone ?
    priuscatprimeguy and 4rpr15 like this.
  9. Kramah313
    Kramah313 Active Member
    408
    322
    Dallas, TX
    If you were going to run out of EV miles, then the engine is much more efficient at highway speed than it is idling around town. And EV power is burned up faster at high speeds as well. So in that case it would make sense to let each form of propulsion do what it's best at and turn on the engine for the highway where its fuel efficiency is best, leaving your EV reserve for in town where the engine is not efficient.
    But since you have enough EV to spare, you might as well just use that.
  10. 4rpr15
    1,056
    375
    WI
    Isn't EV Auto supposed to do that
  11. Kramah313
    408
    322
    Dallas, TX
    Yes, but it has fixed parameters and can't plan ahead. EV auto doesn't know you have 5 miles of stop lights after your freeway drive and to save EV for that when you're only doing 60 on the freeway, which EV auto might leave to the electric motor since it isn't demanding enough for the car to decide the engine should help. EV auto figures if you are demanding hard acceleration or traveling at very high speeds to go ahead and start the engine for power assist. So it's a similar idea, but without the benefit of knowing your route.
    Full disclosure - I don't have a prime so I don't know exactly what the EV auto parameters are for kicking in the engine, I am basing this off of what I have read and info from other owners.
    An example from my gen 3 - there is a long stretch of 35 mph road on my drive home that the car likes to shut the engine off, but it uses a lot of battery power that sometimes isn't available for the 25 mph stretch and parking in my garage after that. I usually do a light pulse and glide to try the keep the engine on and save battery power so the battery isn't empty and the engine running while I'm going 2 mph trying to park. If I had an EV hold feature I would turn it on there because I know there's a better EV stretch coming up, which the car can't know. It just knows it can shut off the engine at 35 mph.
    Way too long story (sorry) short - it only really comes into play when you are dealing with running out of EV power at some point.
    4rpr15 likes this.
  12. 4rpr15
    1,056
    375
    WI
    Should I manually turn HV mode on as I'm entering the freeway? Turn it off as I exit?
  13. Lee Jay
    Lee Jay Senior Member
    5,850
    4,024
    Westminster, Colorado
    The whole point of the charge schedule and not charging until you need to is to preserve battery longevity. The longer you leave the battery at full charge the more it degrades.
  14. bisco
    49,520
    there is a battery preconditioning system that it needs to be plugged in for, you may want to investigate that.
  15. Kramah313
    408
    322
    Dallas, TX
    Yeah that's how you'd do it. But honestly I would just use EV mode. If I had a 19 mile trip and a prime that is what I would do. But if I thought I might run out I would turn on HV on the freeway as you said above.
  16. 4rpr15
    1,056
    375
    WI
    I prefer using all EV so I won't waste gas daily to work.
    Kramah313 likes this.
  17. Kramah313
    408
    322
    Dallas, TX
    I'm jealous of your 19 mile round trip! Mine is about 35.
    4rpr15 likes this.
  18. 4rpr15
    1,056
    375
    WI
    What happens if I charge it at home, but then need to go somewhere and unplug it? Anything drastic over time?
  19. bisco
    49,520
    nothing at all.
    4rpr15 likes this.
  20. 4rpr15
    1,056
    375
    WI
    I usually wait until late to charge it. Anything special that I need to do over the cold winters? I normally unplug it, turn on the heat and go.
