Best roof rack to add to 2012 Prius Three for Kayak
Discussion in 'Gen 3 Prius Accessories and Modifications' started by pinkkitty724, Mar 28, 2013.
  1. pinkkitty724
    pinkkitty724 Junior Member
    65
    I am looking into getting a roof rack system for my 2012 Prius Three. Mainly this will be used to carry our Hobie Kona kayak, and if possible, bikes in the future. If not bikes, then we'll need to invest in a separate bike carrier for the hatch.
    I am a little worried about the MPG impact, and damaging my car... so, those of you experienced may have some insight and experience with specific racks that you can recommend.
    Being completely unfamiliar with roof racks- can they be removed when not in use? Or will some part of it remain at all times? I assume I could easily remove cross bars, and I assume that the brackets which hold them remain in place at all times?
    What are the best brands? What are the tried and true on the Prius 3rd Gen? I am in the US (if that matters?) Thanks all :)
    JMD likes this.
  2. wjtracy
    wjtracy Senior Member
    11,312
    3,588
    Northern VA (NoVA)
    We have one PriusChatter putting his kayak inside the car but he has a 9.5-ft'er. Another guy with 10-ft kayak lets his stick out the back and he uses some bungee cords to hold the liftback down. I put my kayak inside my minivan. Most of us use the removable racks though. Then you geta kayak carrier from REI etc. I could use a kayak rack too, to be honest.
    A really great roof rack no longer made is Saris. Sometimes Gen2 users sell them. Don't know if they fit Gen3, if I recall someone said they fit a v very well. In the lack of Saris, something like Thule Aeroblade looks good.
  3. pinkkitty724
    65
  4. pinkkitty724
    65
    Our Hobie Kona is almost 12' so I couldn't put it inside :) plus we live in a Coastal area so the salt water would cause problems for my interior because I have no way to rinse the kayak until we get home.
  5. wjtracy
    11,312
    3,588
    Northern VA (NoVA)
    ...did you have a comment?
  6. ewxlt66
    ewxlt66 Active Member
    535
    186
    Dana Point, CA
    photo-5-14.jpg I would suggest having the Yakima Landing strips installed. Infinite adjustability with the most low profile set-up.
    Like this:
  7. pinkkitty724
    65
    Thanks! That may not be bad. Is that bad for aerodynamics though, since they are permanent? And any worry about roof damage or leaks, etc?
  8. pinkkitty724
    65
    Y
    es I did but it wouldn't let me type :) I can from my iPhone though. I posted it above where I meant to originally :)
  9. ewxlt66
    535
    186
    Dana Point, CA
    It won't leak. Professionally installed and they use this sealer that automotive folks also use to seal up holes.
    I've had it done to two cars.
    With the Yakima set up you can quickly remove the crossbars and towers leaving only the bases attached.
  10. pinkkitty724
    65
    Tha
    Thanks! Ill have to look and see if we have any local installers in my area. I like the idea that the bases are relatively flat to the roof.
  11. ewxlt66
    535
    186
    Dana Point, CA
    Where are you located?
  12. pinkkitty724
    65
    Between Pensacola, FL and Destin, FL
  13. ewxlt66
    535
    186
    Dana Point, CA
    Pretty sure there's a Rack Attack company somewhere nearby. Check that out.
  14. pinkkitty724
    65
    I just looked at Rack Attack locations and there are some in MA, OR, CO, MN, Canada...... none near me. Or do you perhaps mean affiliates or something?
    Are they the only ones that install that system?
  15. ewxlt66
    535
    186
    Dana Point, CA
    No no...others do too. I'm in SoCal. I found a place 20 miles from me that does it.
    I'd venture that *most* Yakima dealers could do it or be able to tell you who could do it.
    If I was in your shoes, I'd call Yakima for a referral.
  16. pinkkitty724
    65
    Thank
    Thanks again! I wasn't sure where to begin I guess. I will contact Yakima and see if they can tell me if any local companies do the installation. :)
  17. ewxlt66
    535
    186
    Dana Point, CA
    Sounds good. Let us know how it goes. I've done this to my truck and my wife's Ford Flex. Next up is my Prius!
  18. pinkkitty724
    65
    Eek! The closest place that does installation is in Jacksonville.... just over 5 hours away! There are companies that sell Yakima which are closer, so I will contact them to see if they know of anyone closer that installs.
  19. ewxlt66
    535
    186
    Dana Point, CA
    Darn it. Good luck on finding a closer spot.
  20. pinkkitty724
    65
    Yup. It kind of stinks. There are local places that sell them, but don't install them. One that sells them asked me if I REALLY want to drill holes into my car....
    I am starting to think it's not the best idea?! My husband asked me the same thing and wants me to get something less permanent.
