Best ties for an '07 Touring
Discussion in 'Gen 2 Prius Main Forum' started by derh2o, Nov 21, 2008.
  1. derh2o
    derh2o Junior Member
    34
    I had my mind up on buying Michelin X tires at Costco. I went to buy them today but was told they did not stock the 16" tires for the Touring model. All they could offer was the Michelin Pilot Primacy. They did not know if it was a low resistant tire or not. Michelin web site did not appear to offer a 16" X tire. I am now back to ground 0. Any recommendations for a low resistant 16" tire for my Touring?
  2. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    ii use the pilot primacy. they are the tires toyota japan puts on. really quiet. rates good. but beware there is no tread life warranty on these tires. they are kind of expensive too. maybe about 140 and up
    the other ones are bridgestone turanzas. that is what toyota puts on the touring here.
    they have a tread life warranty, but you have to actually purchase them, if they came with the car then you are not covered...
    another good tire that rates well and costs about $80-99 is the falken ze 912. they have a 40,000 mile warranty. and the tire has built in wear indicators that tell you when its time to rotate them
  3. rigormortis
    1,340
    26
    san jose, ca
    your other choices are very scarce, mostly run flats.
    if you want to upsell to 205 / 55 / r16, this will increase your selection to about 60 tires, but this will reduce your mpg slightly.
    i think the falkens are the one to get. they have a tread wear number of 360
    prius cars seem to shave tires. so the higher the number is probably better
    tread wear guarantee is something u want, i think
  4. rigormortis
    1,340
    26
    san jose, ca
    oh yeah, when it comes to balancing the tires, ask the tire place to use sticky weights. thats what i did. they are stickers and they go on the wheel
    i didn't feel like wanting them pound on the regular tire weights on my rims, so i had them use the stickers instead
  5. Ron Dupuy
    Ron Dupuy New Member
    112
    Fortuna, CA
    I think a bow tie would be good.
  6. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    There are very few non-runflat tires available in the Touring OEM 195/55/16 size, and most in this small group will be performance tires and not have a very low rolling resistance or long tread life.
    If I were you and really wanted the Michelin X Radial, I would move up to the 205/55/16 size. My bet is that any mpg loss will be minimal -- between 0 and 2 mpg, and will be far outweighed by the gains.
  7. Doc Willie
    1,717
    144
    Out there, somewhere
    Regular weights will also mar the alloy rims.
  8. problemchild
    problemchild New Member
    429
    37
    It never ceases to amaze me how far off topic this forum can take a thread.
    --------> He asked about tires<-----------------
  9. rigormortis
    1,340
    26
    san jose, ca
    i suggested the weights, being a 2007 touring, he probably never had the tires replaced or balanced
  10. jdenenberg
    jdenenberg EE Professor
    3,926
    1,923
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Just a side note: "Run flat" tires will, in general, noticeably reduce your MPG. They work by having a stiff sidewall (thicker materials) which increases the rolling resistance.
    JeffD
