Best way remove stuck cd
Discussion in 'Gen 2 Prius Audio and Electronics' started by Gnarly, Mar 13, 2017.
  1. Gnarly
    Gnarly Member
    139
    How do I remove a stuck CDR from my 05 Prius base model?
    Thanks,
    Gnar
    Silver_Prius_2006 likes this.
  2. Gnarly
    Gnarly Member
    139
    Also, if I have to buy a new one from FleaBay. How do I know which one is identical to mine without having to open up the car radio console first?
  3. cyberpriusII
    cyberpriusII Prodigyplace says I'm Super Kris
    1,136
    1,580
    Iowa
    bisco and Gnarly like this.
  4. J Conner
    J Conner New Member
    25
    Austin, TX
    IMG_6766.JPG fullsizeoutput_1e0b.jpeg fullsizeoutput_1e0c.jpeg I had no luck trying several times to reset the stuck CD error by removing the cabin ACC fuse beneath the steering wheel.
    To remove a stuck CD caused possibly by a broken ejector mechanism (?), put some double-sided tape on one side of a very thin ruler/straightedge (thin like 1/32 " or 1mm), insert into the CD player several inches with the tape side down, press the eject button, and the CD should be pressed upward inside the player into the tape. Pull the ruler out and it will draw out the CD with it.
