Best way to accelerate
Discussion in 'Gen 2 Prius Main Forum' started by Semicharmedguy26, Dec 16, 2004.
  1. Semicharmedguy26
    Semicharmedguy26 New Member
    Whats a better way to accelerate from a stop? quick and steady (not flooring it but just a good rate) or slow and steady?
    It seem to me that using a slow acceleration prolongs the amount of time the ICE runs and doing a quicker accel would let me get to speed and start coasting sooner and getting off the ICE.
  2. TonyPSchaefer
    14,816
    2,500
    66
    Far-North Chicagoland
    I have just recently started paying extra close attention to my dead-start acceleration. Much to the chagrin of the people behind me, I find it best to accelerate slowly and steadily. Usually, two cars from the other lane pass me within the first few seconds. But in the end I usually catch up with them.
    (this pertains to situations when coasting to stoplights and stop signs is not possible and you are forced to start from a dead-stop)
    As people have noted, the sound and feel of the Prius drive train (Adkins?) is so different that you really have to intentionally acquaint yourself with it.
    Now that I don’t have a stereo, I can really listen to the engine. I never realized how much I push on the pedal when I really don’t need to. When I hear it revving too much I let up and usually there’s no drop in speed. Some days, I spend so much time trying to lift my foot off the pedal, my shins are sore when I’m done.
    Rather than participating the “stop light Grand Prix†with the other cars, pay more attention to your speedometer. You will see constant acceleration even though you don’t feel it. What I normally try to stick to is, “if you see the speedometer skipping numbers, you’re accelerating too quickly.†You will be surprised by how quickly you are up to speed.
  3. skruse
    skruse Senior Member
    1,454
    97
    Coloma CA - Sierra Nevada
    I find it is best to accelerate somewhat rapidly from a stop sign or stop light. Once I reach about 28 mph, I engage the cruise control, then use the cruise control to accelerate further. This seems to be a good balance between the ICE and electric modes. Police pursuit driving trains you to have a sense of your "seat" and the center of balance in the vehicle. Coupled with the sound of the engine, you quickly learn how fast to effectively accelerate. Braking shifts the center of gravity to the front wheels, acceleration shifts the center of gravity to the rear wheels.
    As conditions permit (light traffic, not major highways) I can set the cruise control at 41 to 51 mph (depending on road grade) for optimum continuous performance (velocity, fuel economy, battery recharge). I have been concerned about fuel consumption, but average 51-53 mpg using this technique.
    On major highways I continue to accelerate with the cruise control to 66 to 70 mpg and average 45-51 mpg with continuous driving.
  4. Prius Maximus
    Prius Maximus Senior Member
    955
    809
    Northeastern IL
    I believe that a slow steady acceleration is best.
    If cruising speed is over 40, I try to accelerate using only the ICE, not drawing from the battery. (Keep the arrows to the battery or no arrows to or from the battery). Accelerating faster drains the battery which then requires recharge and consumes energy. If cruising speed is under 40 , I try to stay in EV as long as possible and then feather into EV as soon as I can. This of course depends on how close I'm being tailgated!!
    I believe in Physics and the laws of conservation of momentum, and efficiency. It takes a certain minimum amount of energy to accelerate a mass to a certain speed. The time it takes does not matter, however, doing it too fast requires extra energy and is less efficient. Doing it slower may help if you can stay in EV. It is not a matter of getting up to speed in ICE as fast as possible to get to EV sooner. Watch your MPG when going at different acceleration rates. Pedal down and MPG is 6 to 8 or so. You use a lot of extra gas to overcome inefficiency (but it is fun when you can stop that punk in the right lane from getting in front of you just because he thinks he's got a fast car).
    Remember, the idea is to use less gas. The less gas you use, the better the MPG will be. As you drive think: how can I drive with less gas usage? Can I coast a little more? If I let off a liitle up this hill, I can get back up to speed on the down side. Nobody behind me - I'm coasting a 1/4 mile to the stop sign. If the speed limit is 40-45, I'm doing 39 to be in EV (as long as nobody's behind me).
    Anything over 63-65 really starts sucking down the gas - wind resistance. Over 70-75, you might as well be driving anything else on the road. I never use cruise control. I tried it, and I do much better. It can't anticipate, it can only react.
  5. 8AA
    8AA Active Member
    550
    62
    Maryland
    Brisk acceleration (but not hard acceleration) is better. If I don't have anyone behind me, and can accelerate in electric mode, I will until the ICE kicks in and then I accelerate briskly up to the cruising speed. If there was a direct conversion of the gasoline into kinetic energy, then I would agree that the rate of acceleration did not matter. Unfortunately, internal combustion engines are not that straight forward. Watch the instantaneous MPG reading and try a slow acceleration, and then a brisk acceleration. I think you'll find that accelerating twice as fast won't mean that you use twice as much gas. However, try a hard acceleration, and you'll find that gas consumption goes way up.
  6. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    I am presently in the brisk acceleration group. I am very interested in the course of this thread. I really picked up on this on a weekend when I had to make a few banzai runs to the hospital. I thought I was really going to take a hit on the M.P.G. but I actually did a bit better that expected. I am of an age where I am beyond drag race starts and speeding, but I do need to move along. I would like to hear more from the most experienced folks around here.
  7. flareak
    flareak Fleet Captain
    1,016
    St Louis, MO
    Ok, I'm really curious as to which type of acceleration is better. Please post some MPG figures as well as miles on the odometer to compare which saves more gas. Certainly different factors will influence the MPG of each person but maybe we can see a general trend.
  8. pafoss
    pafoss Plug-in Member
    Denver, CO
    I am certainly not one of the most experienced at this yet, but I started with mild accelerations and have been experimenting with more brisk accelerations. I have not determined yet the optimal level of "briskness" quite yet, but I do believe it is more efficient on the whole than the slow starts.
    My $0.02,
    Powers.
  9. justwatchme
    justwatchme New Member
    52
    Ca
    i use the motor as long as i can then when the engine turns up do a brisk acceleration then just cruise at the speed i want. I think getting kinda bad mpg for like 3-4 seconds is better then getting decent bad mpg for a much longer period of time. Kinda like lifting a really heavy weight you use less energy just getting it up fast (up to a point) and letting momentum help you rather then lifting it slowly.
  10. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    The owners manual clearly advises "moderate" rate of acceleration. John1701a suggests brisk acceleration...or about 70% of maximal.
    Getting the ICE up to it's most efficient RPM (best power for fuel consumption ratio) is clearly the goal if most fuel efficient accleration is your goal.
    Accelerating too slowly never allows the ICE to reach that efficient RPM (~4-5k rpm). Also, the ICE has poor power and torque from a dead stop. Although it 'may' be more fuel efficient (slightly) to use ICE only acceleration (aka Dead-banding) it makes very little sense to do so as acceration would be ridiculously slow in most conditions.
    Thus, I think it is best to take advantage of the design of the Prius. The moderate/brisk acceleration allows use of the battery and motor while also allowing the ICE to spin up to it's most efficient RPM. Once you're close to or hit your desired steady-state speed back off and let the ICE maintain it's most efficient RPM and recharge the battery as necessary.
    The difference in fuel efficiency is negligible, the difference in the driving experience is huge. Your fellow road-sharers will thank you.
    In 'real life' what I find that works great for me is to briskly accelerate (as above) until I get to about 35-45mph (depending upon traffic), then throttle back to a deadband acceleration (assuming a level road) until I achive my highway speed. I usually get to 60mph in about 20 seconds with that and haven't ticked off anyone that I'm aware of....my lmpg is pretty decent.
  11. Frank Hudon
    Frank Hudon Senior Member
    4,147
    start off in electric till about 20Km per hour, 12 miles per hour, that usually starts the ICE and then do 3500 RPM till I get to almost the speed limit and then completely back off the trottle which makes the computer think your going to coast then slowly add throttle to maintain speed. I don't pulse drive. Most times I'm better than the cruise control as we have lots of hill here, unless I'm on the hiway then it's cc all the time.
  12. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    ive attempted several times to drive any appreciable distance using both gradual and brisk acceleration and have never been able to stick to one or the other for a long enough period of time to get any real difference in data.
    unless you can do this in a controlled environment, its nearly impossible to pull data out of driving when all driving conditions affect your mileage so much.
    brisk or gradual acceleration can be a minimal or significant factor in the overall gas mileage you get. i have often kicked around the idea of going to a large parking lot where i can get up to say 40 mph. i figured something at least a half mile in length where i would either accelerate and drive before coasting a block or so while coming to a stop, turning around and doing it again several times.
    then try accelerating very gradually up to 40 mph and slowing down at the same rate as before.
    but just havent been motivated enough to try it.
    to be honest with ya, i think the slower you accelerate the better the mileage just like any other car. i understand that the slower you accelerate the longer the ICE runs. but in the grand scheme of things, it still takes the same amount of force to go the same distance. so we have to look at what is more efficient. batteries are notorious for being inefficient and converting energy to electricity isnt that efficient either. now after the electricity is made, electric motors are very efficient but its still all coming from gas so i feel that using the electric motor is efficient but using battery power isnt.
    so we come to gas engines which are notoriously bad for wasting energy. but when the Prius is running the engine to power the AC motor, that is where its at its most efficient. The ICE by its design is meant to maintain momentum not accelerate. so i believe that fast acceleration is using the Prius at its worst. when you have primarily the ICE working especailly for high torque applications you are losing because that is what the EV was for.
  13. daniel
    14,487
    1,519
    Spokane, WA
    My opinion: Just drive it!
    Interestingly, the original poster asked what is "best" without specifying any criteria. If you could increase your mpg but get intentionally rammed, or even shot, by some lunatic in a fit of road rage because you took 5 seconds longer to get up to speed than the cars in the next lane over, that is clearly not the "best" outcome.
    But I agree with Evan, above (and with John1701a) that you get the best performance with a brisk (not jack-rabbit) acceleration.
    While it's true that batteries are not efficient, simplistic analyses will not work with such a complex system as the HSD. Accelerating on battery power alone is probably a bad idea because of the battery inefficiency, the relatively small amount of energy stored in the battery, and the large amount of energy required to accelerate the car. But trying to force a dead-band (no battery) acceleration is probably not a good idea either because it is not taking advantage of the whole system. The Prius is designed to use gas and electric together, and is probably at its most efficient when allowed to do so.
  14. tntna
    tntna New Member
    131
    Central OH
    With the Classic Prius, I swear by the slow start. However, the 05, I'm leaning toward a more brisk start. My wife has had the 05 Prius the last couple of days. She runs the heater, I don't. She drives more quickly than I do including the acceleration and abrupt stops. Somehow she added 2 to the mpg when I suspected she'd lower it by 2. This is with over 200 miles already on the tank. I just don't get it.
  15. Eisenson
    Eisenson New Member
    142
    I've done a lot of experimenting with the advantage of extra instrumentation. Read Evan's comments carefully - I think he's nailed it, and there's no need for redundancy (just a geek's endorsement).
  16. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    I keep up with traffic, period. I don't go faster, and I sure don't go slower. In city traffic, or busy intercity traffic, keep up with the flow, period.
    A lot of Americans have watched Michael Moore's "Bowling For Columbine" and have the wistful notion that Canada has zero crime and we all leave our doors unlocked.
    Two words: Bull and S***!
    Home invasion is one of the fastest growing crimes up here in the Great White North. Leave the doors unlocked? Wow, what is that Michael Moore smoking?? :pukeright:
    Road rage can and does happen here, and even guns can be involved. More often though, you can be rammed off the road, or the person will force you to stop and then stab you or beat the s*** out of you.
    Then thanks to the Liberal Left Wing judges, the crook only spends 2-3 months in jail. If he goes to jail. There was even a case here in Winnipeg around 5 years ago when two off-duty RCMP officers committed an act of road rage. They got off.
    As far as finding the "optimal" acceleration band, that would be easier if the Prius had a tach. The Insight does, why doesn't the Prius??
  17. tntna
    tntna New Member
    131
    Central OH
    Well that's it... I'm not moving now. :)
  18. daniel
    14,487
    1,519
    Spokane, WA
    A tachometer would be pointless in a Prius, because the engine speed is almost completely decoupled from the vehicle speed. The PSD allows the engine to run at or near its most efficient speed regardless of vehicle speed.
  19. daniel
    14,487
    1,519
    Spokane, WA
    I think Jayman is just trying to discourage us US-ers from moving to Canada and ruining a good thing. I've been to Winnipeg (several times), Regina, Saskatoon, and the Selkirk Mountains of BC, and I think Canada is a great place with great people. Sure, there's crime everywhere, but if I didn't have roots here in Fargo, I'd be sorely tempted to move to Canada. Jayman, you've got a great country!
  20. efusco
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(daniel\";p=\"58269)</div>
    While I agree that there are many times it would be pointless, this acceleration from a stop or a significant acceleration from one speed to another might just be a situation it could help.
    IF we knew the most efficient rpm, or a narrow range it would give us a target for our 'brisk' acceleration. Once we got to that point we hold the acceleration rate until we hit our desired mpg.
    No, I don't think we'd see a 10% improvement in mpg with it, but it might add a few tenths or even 1-2mpg (depending upon previous driving habits) and would provide some more objective feedback than engine noise and 'seat of the pants' sense of how fast we were accelerating.
    Once at cruise or for minor changes in speed and such I do think you're right that it would be, for the most part, pointless.
