Best way to repair a ding on Spoiler?
Discussion in 'Gen 3 Prius Main Forum' started by MPGHokage, Nov 3, 2019.
  1. MPGHokage
    MPGHokage Junior Member
    Utah
    I'm assuming this is still called a Spoiler anyway lmao. This morning I went to Dennys, and then went to get an Oil Change, when we were handing over the keys to the Mechanic I noticed this (See Picture)
    Like somebody smacked into it with a little bolt somehow???
    Anyway. What would be a good way to repair it? is there some kind of epoxy i could use? and Where would I be able to find Paint to match this piece? Thanks!
  2. Mendel Leisk
    41,126
    I would try to level it a bit with the abrasive pen on a Dupli-Color applicator, then wipe it down with isopropyl alcohol, and apply body filler with indents. When cured sand with fine grit, try to keep it as localized as possible. Then a few strokes with the paint brush of the applicator. Dupli-Color Scratch Fix All in 1 - Universal Black CASF0100. It won't be perfect, but it's on an edge, and low, so not bad.
    I've done bad things to ours more times than I can count, with the garage door...
    MPGHokage likes this.
  3. BZzap!
    BZzap! Senior Member
    1,607
    878
    I’ve found that the best way to protect the (vulnerable) edge of the spoiler is with a bit of prevention. In doing so, I’ve install rubber moldings on my garage door. Unfortunately, this was an afterthought, so I have several pre-prevention chips in the trailing edge. I’ve looked and looked for edge protectors of some sort but haven’t been able to find anything that would not look out of place. I’ve just resigned myself to living with it. Maybe some day I’ll sand it out and repaint the spoiler...some day.
    BTW, don’t let the kids or the Wife, open the hatch without your supervision because, mysteriously, these chip just appear like magic!!!
  4. Mendel Leisk
    41,126
    I've managed to be the culprit for all the dings on ours... :oops:
    Yeah I put some pipe insulation (dense foam tubing) on the trailing arm of our garage door opener. It helps somewhat. Usually it jumps the tracks a bit, which helps too.
