Bets for weight of 2009 Prius?
Discussion in 'Gen 2 Prius Main Forum' started by clett, May 21, 2007.
  1. clett
    clett New Member
    537
    Scotland
    To meet Toyota's ambitious aims for the mileage of the upcoming revised Prius next year (MY09), while still cutting costs over the existing model, I suspect that the new Prius will have been on a comprehensive weight-loss programme!
    Does anyone here have any guesses as to how much the 2009 Prius will weigh in?
    Existing Prius: 1325 kg (or 2921 lb)
    My bet for new Prius: 1190 kg (2620 lb, or 10% lighter).
  2. Platypus
    Platypus New Member
    43
    Sacramento, CA
    <div class='quotetop'>QUOTE(clett @ May 21 2007, 08:07 AM) [snapback]446656[/snapback]</div>
    Well switching from the NiMH battery chemistry to the Lithium one is going to save a good bit of weight or if they enlarge the battery and keep the same weight it will have a lot more capacity. Switching over to Lithium will also realize efficiency gains in conversion of the electrical and chemical energy between the motors and battery. Despite the benefits, lithium batteries still misbehave in spectacular fashion when they are not treated well and that's a problem for the accident scene. We'll see what Toyota does.
    NiMH (20-80 Wh/kg)(66% charge/discharge efficiency)
    LiIon / LiPoly (150 to 200Wh/kg)(99% charge/discharge efficiency)
    [tinfoil]
    The change to Lithium is also probably being pushed by the fact that Toyota got nailed with a 30million dollar lawsuit by Chevron over NiMH battery patents and production that Chevron took control of when they bought Texaco (who bought them from GM) a few years back. This is a big reason that the electric only RAV4 EV is no more... [/tinfoil] :p
  3. ystasino
    ystasino Active Member
    793
    50
    Tucson, Arizona
    <div class='quotetop'>QUOTE(Platypus @ May 21 2007, 12:31 PM) [snapback]446711[/snapback]</div>
    Bet: 1155 Kg
    And I bet that with the reduced weight/increased efficiency the 09 Prius will accelerate to 50mph purely on electricity and will reach 50mph faster than this HSD Prius.
    Ninety mpg city driving: Helllooooo dollie!!!
  4. Mr.Vanvandenburg
    1,328
    544
    2020 Prius Prime
    Consumer Guide had an article that thought the new Prius would be a 2010 introduced in 2009. I am pretty happy with my efficiency, and am a bit skeptical about wild claims. Energy needs to be consumed to move the thing. Already we see that if the Prius is driven in all electric mode and runs down the battery, it is less efficient to use the engine to recharge the battery than to use a combination, as the HSD does well. It may be better, may not, depending on the sacrifices needed to achieve those high numbers. Most people just don't want to drive slower and easier, which conflicts with efficiency big time. Already we see the Prius can get very high mpg's from some users, but a lot complain too. I am happy with it.
  5. Tideland Prius
    16,445
    1300-1400kg.
    Why? because while they'll save weight with a lighter, denser battery pack, it's also just as likely that airbags (those aren't taken into account on the base weight cause they're lazy and just use the 04-06 weight for 2007), VSC might be standard so add that too. The possibility of a larger 1.8 litre engine may negate the weight savings by the smaller battery pack.
    Stuff like power seats or SKS that become standard will add weight.
  6. tballx
    tballx New Member
    130
    Edmonds
    <div class='quotetop'>QUOTE(Platypus @ May 21 2007, 09:31 AM) [snapback]446711[/snapback]</div>
    Tinfoil? You're entirely too hard on yourself. These companies would drill for oil in your forehead if the ROI was right.
  7. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    <div class='quotetop'>QUOTE(Tideland Prius @ May 21 2007, 02:45 PM) [snapback]446846[/snapback]</div>
    I agree; any weight savings will be offset by the addition of more 'stuff,' a bigger engine, etc.
